Author Topic: 1st Project - Galaxian cab #19,267  (Read 5148 times)
gShooter
  • Last login:March 10, 2016, 02:12:46 pm
« on: August 08, 2010, 12:11:19 am »
Long time lurker, first time project.  I bought this cab today via a local dealer for $50 after buying a Tekken 4 last month for $50 as well.  Pretty sweet deal considering it's an original Galaxian cab and it included the original bezel, marquee, coin doors, and control panel.  After about 2 hours of work, the cab is essentially stripped.  You can see from the picture below, somewhere along the line it had the sides painted black and a pale blue on the front.  After removing the coin door and mechs, you can still see the original Galaxian graphics and white cabinet color under the coin door frame.  I figured posting it here would motivate me to complete it a little quicker than it I hadnt plus get some great feedback.
My plans are:
1. clean everything up
2. correct all surface damage
3. either repaint or laminate the surfaces
4. install new 19'' monitor
5. since there isnt a pcb, install new multicade board
6. install new cp with trackball
7. install new JAMMA harness
8. install new power supply
9. install light source for backlighting the marquee
10. install a few modern AC accessories
Galaxian Cab #19,267
Coin Door
Coin Door Removed
Control Panel
Control Panel stripped
« Last Edit: August 08, 2010, 12:20:54 am by gShooter »
darcyp
  • Last login:September 19, 2012, 12:22:17 pm
Re: 1st Project - Galaxian cab #19,267
« Reply #1 on: August 08, 2010, 12:38:53 am »
nice find! other than the trackball, what kind of cp are you going to have in there?
gShooter
« Reply #2 on: August 08, 2010, 12:56:18 am »
Something simple.
1 - 8 way
3 - buttons
1 - trackball
2 - buttons for 1/2 player select
I really want to get the coin mechs up and running so I can use it as sort of a piggy bank for myself.  I'll give the wife the keys to the machine when complete.
Havent figured out yet exactly what size trackball I should use, but I have some time I think before I get there.  Ordered the board, harness and power supply yesterday.  New monitor came a few days ago.  All in all though, this is panning out to be much cheaper than I had originally expected.
I think it will be awesome to have a bunch of the old style vertical games in a Galaxian cab.
« Last Edit: August 08, 2010, 01:00:29 am by gShooter »
danny_galaga
  • Last login:Yesterday at 11:04:42 pm
    • dans cocktail lounge
« Reply #3 on: August 08, 2010, 06:30:41 am »
Are you getting new Galaxian side art?
gShooter
« Reply #4 on: August 08, 2010, 06:51:03 am »
That would be the last step along after I had every thing up and running.
UPDATE:
- Ordered the new powder coated CP
- Ordered new CP overlay
- Ordered new buttons (5 red - 2 white)
- Ordered lime green t-molding
Still shopping for:
- Joystick
- Trackball
« Last Edit: August 09, 2010, 12:18:14 am by gShooter »
gShooter
« Reply #5 on: September 21, 2010, 12:48:24 pm »
21 Sep 2010
Spent a fair amount of time this weekend on the cab.
All the parts have arrived.  Waiting till the paint process is complete.
- all surface damage repaired, replaced
- replaced inner 2 partitions (1/2'' birch plywood)
- sanded, filled, primed (2 coats) inside and outside of cab
- control panel overlay and controls installed (still cant find 3'' carriage bolts easily)
« Last Edit: September 21, 2010, 12:50:44 pm by gShooter »
gShooter
« Reply #6 on: September 26, 2010, 09:32:26 pm »
26 Sep 10
- First coat of white on the sides, front, and back today after 2 coats of primer.
- Also purchased a pair of shielded/amp speakers - Logitech X-140's for a decent price
http://www.amazon.com/Logitech-970264-0403-X-140-2-0-Speakers/dp/B000IF4788/ref=sr_1_7?s=gateway&ie=UTF8&qid=1285551064&sr=8-7
Crayola
  • Last login:October 10, 2012, 04:13:23 pm
« Reply #7 on: September 26, 2010, 10:13:29 pm »
Pics!
what track ball are you going to use? I need to pick one up
for my metal CP.
Crayola
gShooter
« Reply #8 on: September 27, 2010, 10:06:36 pm »
I bought an Atari 2.25 inch at Arcadeshop.com.  I also splurged and got the JAMMA trackball harness, powder coated cp (1 joystick, 5 buttons, trackball), and cp overlay.  Very friendly, quick shipping.
Hardest part has been finding 3'' carriage bolts which I finally found at grooveygear.com at a decent price.
FlatEarth
  • Last login:September 14, 2021, 05:58:04 pm
« Reply #9 on: September 28, 2010, 07:01:27 pm »
I am curious, which Arcadeshop.com control panel did you get for your Galaxian?  The panels I see there are Galaga/MsPac panels, and from Crayola's experience I thought those panels are not a direct replacement for Galaxian/Pac cabs.
gShooter
« Reply #10 on: September 28, 2010, 10:04:53 pm »
This one is the one I purchased along with the overlay.
http://www.arcadeshop.com/pics/multicade-ur-panel-tb.jpg
« Last Edit: September 28, 2010, 10:06:28 pm by gShooter »
FlatEarth
« Reply #11 on: September 30, 2010, 04:42:55 pm »
gShooter,
Have you tried your new CP on the Galaxian cab?  I am very curious to know if it fits, if it does I may order one myself!
gShooter
« Reply #12 on: October 02, 2010, 09:58:37 pm »
It fits fine.  I'll post some pics tomorrow.
-  Finished almost all of the white and black painting today.  Just have the shelves left.  Gotta work the powered speakers (X-140s) in the shelf tomorrow.  If all goes well, might even get to play a few games.
- swapped out the screws for carriage bolts on the trackball (carriage bolts from Crow River)
- swapped out the pushbuttons for convex pushbuttons
« Last Edit: October 02, 2010, 10:02:59 pm by gShooter »
Crayola
« Reply #13 on: October 03, 2010, 01:23:04 am »
I tried an original Galaga control panel on the Galaxian cab.. didnt fit.
Never tried the multicade ones arcade shop sells. They might fit.. dont know
gShooter
« Reply #14 on: October 03, 2010, 04:32:22 pm »
03 OCT 2010
Got a fair amount done today....not as much as I wanted, but a solid amount.
Here are the pics I promised:
Speaker Installation
* The speaker install went fairly smooth.  For the future, or next build, I will buy a hole saw.  The Porter Cable jigsaw I have will be going back for the Dewalt I should have purchased.
Control Panel Dry Fit
* The control panel is pretty simple.  There is a small 1/8-1/4 inch gap along the edge of the panel.  I think that a small strip of auto door edge molding will make it snug.
« Last Edit: October 03, 2010, 04:39:48 pm by gShooter »
Spyridon
« Reply #15 on: October 07, 2010, 05:17:26 pm »
Why did you strip the control panel if you were getting a new one?
gShooter
« Reply #16 on: October 07, 2010, 09:54:03 pm »
I was bored and waiting for parts plus I had a free powder coat spot.
gShooter
« Reply #17 on: October 13, 2010, 09:27:29 pm »
Close up of the install
Both of the speakers installed
The backside
« Last Edit: October 13, 2010, 09:34:00 pm by gShooter »
