Author Topic: EPIA Mini-ITX M10000, will it work?  (Read 3668 times)
JAFloriano
  • Last login:August 16, 2010, 03:26:33 pm
« on: August 07, 2010, 08:04:14 pm »
I had an extra EPIA Mini-ITX M10000 from when i wanted to make a carputer(Specs below)
I was wondering if it would be powerful enough to run a jukebox with windows XP?  I wanted to make a compact jukebox and this guy is pretty small.
VIA C3™/ VIA Eden™ EBGA processor; CLE266 North Bridge; VT8235M South Bridge
1 DDR266 DIMM socket, Up to 1GB memory size
Integrated VIA Unichrome AGP graphics with MPEG-2 Accelerator
1 PCI
2 X UltraDMA 133/100/66 Connector; 1 x FDD Connector
VIA VT1616 6 channel AC'97 Codec
VIA VT6307S IEEE 1394 Firewire
Back Panel I/O - 1 PS2 mouse; 1 PS2 keyboard; 1 Parallel; 1 RJ-45 LAN; 1 Serial; 2 USB 2.0; 1 VGA; 1 RCA (SPDIF or TV out); 1 S-Video; 3 Audio jacks: line-out, line-in and mic-in; can be switched to 6 channel output
Onboard I/O Connectors - 1 USB connector for 2 additional USB 2.0; 2 1394 connectors for 2 1394; 1 Front-panel audio connector (Mic and Line Out); 1 CD Audio-in; 1 FIR; 1 CIR (Switchable for KB/MS); 1 Wake-on-LAN; CPU/Sys FAN/Fan 3; 1 SMBUS; 1 Connector for LVDS module; 1 Serial port connector for a second com port
  • Last login:Today at 04:23:32 pm
Re: EPIA Mini-ITX M10000, will it work?
« Reply #1 on: August 09, 2010, 02:49:23 pm »
audio is audio whether it comes from an ipod a computer or cd player.
if it will run windows xp it's play mp3's
most of the jukebox software started comming out around the P3 era so basically anything over 1ghz is ample.
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
« Reply #2 on: August 10, 2010, 01:39:38 am »
I have that motherboard in a bartop mame machine running TinyXP with 512mb RAM. It does the trick for playing the classic games but I had to downsample mame to 22khz to avoid audio stuttering. I am guessing it should be fine running an mp3 player app but never tried it so I can't say for certain.
"Some drink from the fountain of knowledge; I only gargle."
« Reply #3 on: August 10, 2010, 11:23:35 pm »
i have no idea what your running, but my multimedia pc i use in the livingroom to play hd video on is a 1.2 ghz with 256 mb ram and winxp pro... i even pull the video wirelessly from my main desktop in the office with really no side effects other than being a little slow at booting programs. once it's going it's fine.
Jigenjuke
« Reply #4 on: September 05, 2010, 09:27:48 pm »
I used a couple of these for jukes that I made.  I originally used Virtual Music Jukebox for one of them.  The second I used Freebox which is now called e-touch.  It worked great but I would recommend using 1 gig of ram rather than 512.  Go for it.
Jigenjuke
« Reply #5 on: September 07, 2010, 10:34:12 am »
it works, thats whats in my GF unfinished bartop juke touchcade. Using the onboard audio and everything. I also have 1GB of RAM in it, makes a big difference. Im tryin to find a vid card for it to free up some CPU cycles.
« Reply #6 on: September 08, 2010, 12:25:16 pm »
only if you are able to DISABLE the onboard video in the BIOS... otherwise it continues to run and use up your RAM even though you are using a card. Some you can others you can't, yet still others self disable.
boot it with the card and monitor connected, then connect a 2nd monitor to the on board once the computer is booted, if you see an image, it's still operating and hogging your computer cycles.
« Reply #7 on: September 09, 2010, 02:14:43 pm »
I know =)
