Author Topic: Where to connect the ground wire for a happ trackball.  (Read 1643 times)
justinjstark
  • Last login:May 14, 2021, 02:20:13 pm
« on: August 01, 2010, 06:57:14 pm »
I have a happ trackball and an optiwiz.  The trackball has a 6 pin connector which I have connected to the optiwiz.  But, there is also a big green wire coming form the trackball that says connect to earth ground.  Where is a good place to connect this?  I'm guessing I should not connect it to another ground on the optiwiz since it is such a large wire.  Any suggestions?
Hoopz
  • Last login:Yesterday at 06:24:57 am
  • Intellivision Rocks!
Re: Where to connect the ground wire for a happ trackball.
« Reply #1 on: August 01, 2010, 07:02:28 pm »
This comes up from time to time yet it doesn't yield a definitive answer.   :dunno
Some say that you don't need to attach it while others say to ground it to something like a PC case.  If you can attach it to something like that, I say do it.  It's a little bit of insurance that doesn't take that much work to put into place.  Better safe than sorry.
Here's a detailed thread with good info by 2600, CheffoJeffo (who I failed to give credit to the last time I linked to that thread.   :P ), and others of course.
http://forum.arcadecontrols.com/index.php?topic=54489.0
AMDman13
  • Last login:April 08, 2023, 09:21:58 pm
  • This Cab is going to be the end of me!!
« Reply #2 on: August 03, 2010, 12:29:18 am »
I attach mine to one of the PSU mounting screws at the case.
My old user name was marlborroman13, but I kicked the habit many years ago!
