Author Topic: batch file command prompt issue 2 (solved)  (Read 5279 times)
methodical
  • Last login:July 05, 2012, 07:31:51 pm
« on: July 28, 2010, 10:14:00 pm »
I can run games from batch files in MA with no problem but when I exit the game I still see the command prompt window over MA. How do I get this to close when the game closes? I thought "Close all additional processes started during launch" would fix it, but no luck.
« Last Edit: July 29, 2010, 10:29:14 pm by methodical »
methodical
Re: batch file command prompt issue 2
« Reply #1 on: July 29, 2010, 11:40:31 am »
Can you give me an example text from a batch file you're using? Maybe I'm missing something.
methodical
Re: batch file command prompt issue 2 (solved)
« Reply #2 on: July 29, 2010, 10:21:01 pm »
Nope... didn't even know there was one, guess I need to look around a little more, lol.
That did the trick... thanks :-)
