Author Topic: Controller help and HS - Aimtrak Problem??  (Read 1778 times)
Firebat138
  • Last login:January 23, 2025, 05:14:38 pm
  • Head Brewer and Arcade Enthusiast
« on: July 27, 2010, 11:51:42 am »
Ok... So I have been messing around with this for a while now...  I have a 4 player control panel...see my sig for pics...
Two Aimtrak Guns...  The CP uses GpWizs...  When I am in Hyperspin and the guns are plugged in I can not get the JOYSTICKS to work in HS.  When I choose a game, they work fine, cause the mame.ini is in control now... When I unplug one aimtrak and then change the joy ids in the settingss.ini file to 1 and 2 instead of 2 and 3, like HyperHQ says, the JOYS WORK...., but my button assignments for Esc, Favorites, Genre, etc will not assign correctly...  I have Windows 7 64 Bit and when I try and use the Aimtrak software, it crashes...
When in Mame and I configuring the buttons, I know that my Player 1 is actually JOY 2, when I plug the gun back in , it changes to JOY 3...  I think I need to change Aimtraks guns to 1 and 4, but of course the software crashes...   I am almost there...  LOL...  Thanx for advice or help you can offer.
Click below to see my Metal Gear/Splinter Cell Machine... http://forum.arcadecontrols.com/index.php?topic=108360.0
Click below to see my PinCab - PinWARS
http://forum.arcadecontrols.com/index.php/topic,164660.0.html
bkenobi
Re: Controller help and HS - Aimtrak Problem??
« Reply #1 on: July 27, 2010, 11:58:18 am »
Leave the guns plugged in.  If that isn't an option, try using JoyIDs Utility to switch the joystick numbers to a better configuration.
http://www.wingmanteam.com/latest_software/gadgets.htm
« Reply #2 on: January 25, 2011, 11:40:14 pm »
JoyID's will work for some programs but not mame. It doesn't pay attention to Joystick ID's
I just posted a utility to help with this situation.
http://forum.arcadecontrols.com/index.php?topic=108767.0
