Author Topic: Robotron Restoration  (Read 54488 times)
Spyridon
Re: Robotron Restoration
« Reply #80 on: November 03, 2010, 09:50:19 am »
How cold is too cold?  Down near Philadelphia, we should still hit temps in the low 60s next week.  I need to get some paining done in that week!
Most paints state to not use below 50 degrees
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #81 on: November 03, 2010, 12:59:58 pm »
Depends upon the paint.  Please check the side of the can.  Also understand with the cold, the paint will take a LOT LONGER than normal to dry.
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
« Reply #82 on: November 03, 2010, 04:52:11 pm »
I'm getting ready to do my Berzerk... I have a ton of body work to do first... It will be my second stencil.   Did you do just one hit with the stencil colors?
I did one coat of blue, but when I got to the red, I did several light coats over a couple hour period.  I tried to give it some time to dry between coats so it didn't run.  It took a while to cover the blue.  Next time, I may hit it with a coat of white first then the red.
Are you going to add the texture to the Berzerk sides?
No sirreeee.  I hate that finish I don't care if its not original, I would take a nice clean satin black over that textured booger any day!
Happy Gaming!
Kman-Sweden
  • Up the Irons!
« Reply #83 on: November 07, 2010, 01:20:31 am »
Fantastic.
Spyridon
« Reply #84 on: November 11, 2010, 09:14:03 am »
Got a lot accomplished on this.  Pics and update coming soon.
Kman-Sweden
  • Up the Irons!
« Reply #85 on: November 19, 2010, 01:21:31 am »
can't wait.  ;D
Spyridon
« Reply #86 on: November 23, 2010, 04:06:43 pm »
Took some better pictures outside as I was moving the game to the basement arcade for reassembly.
Spyridon
« Reply #87 on: November 23, 2010, 04:38:54 pm »
"Registered" and "TM" symbols added
Spyridon
« Reply #88 on: November 24, 2010, 02:37:03 pm »
The control panel had some major dings in it, so it required some bondo to get it nice and smooth
The rusty t-nuts were replaced with new ones
The metal plates were caked with adhesive and rusty.
These were stripped down to bare metal and painted with black Rustoleum paint
Spyridon
« Reply #89 on: November 24, 2010, 02:41:45 pm »
Time for the new overlay
Problem!  If I line up the overlay to match on the P1, P2, and joystick holes, the left edge is short
I'll need to hit the edges with some black paint so it won't be noticeable.  At the same time, I'll paint a few of the remaining metal parts like the coin doors and marquee bracket
The carriage bolts that hold the control panel on were really rusty.  I put them in my drill and spun them on sandpaper.  Makes them look like new in under a minute
Spyridon
« Reply #90 on: November 24, 2010, 02:46:12 pm »
Once the panel was dry, I applied the new overlay as well as the control panel molding
The edge that was showing now blends in nicely and once on the game I don't think anyone will notice
New translucent blue buttons
Bulbs for the buttons were burned out.  Replaced with new ones
« Last Edit: November 24, 2010, 03:53:34 pm by Spyridon »
  • Last login:Today at 09:13:53 pm
« Reply #91 on: November 24, 2010, 03:03:22 pm »
This is looking great Spyridon!
Great work-around with that CPO problem, and as always, great documentation.  :applaud:
Spyridon
« Reply #92 on: November 24, 2010, 03:52:47 pm »
Joystick actuators (or whatever they are called) were really filthy
so I cleaned them up with soap and water.  Not perfect, but much better
Joystick bases and wire harness in place
Two of the leaf switch tabs were broken and needed to be soldered back in place
Spyridon
« Reply #93 on: November 24, 2010, 03:54:33 pm »
And the completed panel
Spyridon
« Reply #94 on: November 24, 2010, 03:58:05 pm »
I want to bullet proof this game since it won't be local where I can work on it.  I replaced the original harness with a brand new one.  I also have new interconnect cables that I still have to install.  Here is the wire harness.  I'll neaten it up with some wire ties.
Spyridon
« Reply #95 on: November 24, 2010, 04:04:36 pm »
Coin door inserts were cleaned up.  Here is a shot of one clean and one still dirty.  The difference doesn't show too well in the photos, but they cleaned up well.
Marquee light, new monitor and coin doors installed
New marquee and inner bezel installed
Spyridon
« Reply #96 on: November 24, 2010, 04:06:45 pm »
Drum roll please....
 :applaud:  :cheers:
Spyridon
« Reply #97 on: November 24, 2010, 04:09:06 pm »
And a custom attract screen message as requested by the soon to be owner:
Spyridon
« Reply #98 on: November 24, 2010, 04:11:06 pm »
Items left to do:
1. Cut hole in upper back door for new lock (all three locks are keyed alike)
2. Install new interconnect cables
3. Add wire ties to new harness
That's it!
« Reply #99 on: November 24, 2010, 04:22:05 pm »
Just.... beautiful.
This has become one of my favorite games due to MAME, and to see this restoration, it makes me wish I could have played one in its heyday.
MythTrip
  • Last login:October 26, 2011, 08:12:28 pm
« Reply #100 on: November 25, 2010, 09:24:30 am »
Looks awesome, Joe.  Thanks again.   :applaud:
Hope you and your family have a great Thanksgiving!   Also, great to see that your
taking on another Gorf project.
Jim
Kman-Sweden
  • Up the Irons!
« Reply #101 on: November 25, 2010, 02:58:50 pm »
You made it look so easy..    :cheers:
BurgerKingDiamond
« Reply #102 on: December 01, 2010, 07:15:30 am »
WOW. Like a beautiful naked woman. I'm drooling right now. You are a craftsman.
It almost makes me want to play some Robotron. But then I remember how much I suck at it.
-Welcome to the Fantasy Zone.
« Reply #103 on: December 01, 2010, 08:26:53 am »
Is there somewhere I can just subscribe to all of Spyridon's threads?  It's like reliving my childhood, when all the games you walked past were new and shiny.
 :notworthy:
« Reply #104 on: December 01, 2010, 09:16:40 am »
 :notworthy:
Amen. We should pitch in to buy him a webcam so we can watch live feeds!
  • Last login:Today at 10:22:04 am
« Reply #105 on: December 04, 2010, 04:33:11 pm »
Wonderful work!  :applaud:
Spyridon
« Reply #106 on: December 06, 2010, 11:48:06 am »
Well, went to play a game the other day and no sound.  Fuses are still good, but the +12v seems low.
Voltages at the test points are:
+5v = 4.98
+12v = 8.71
-12v = -13.76
Will reflow the header pins first to see if that does anything.  I've been told that sometimes the amp goes bad after the board is recapped.
« Reply #107 on: December 09, 2010, 02:32:52 am »
She's a beauty! Nice job as always!
I hope the reflow fixes your sound problem.
I'd hate to state the obvious, but did you check the volume pot? Perhaps it got accidentally turned...or became faulty. Just throwing it out there...
Spyridon
« Reply #108 on: December 09, 2010, 09:45:28 am »
Nothing wrong with stating the obvious, but yes, I did check that.
Spyridon
« Reply #109 on: December 10, 2010, 04:05:56 pm »
Reflowing the header pins didn't help.  I swapped out the 40 pin 6802 CPU chip on the board with the one on my Sinistar and now I have working sound   :applaud:
Now I just need to order a replacement chip to put in my cannibalized Sinstar sound board.
« Last Edit: December 11, 2010, 08:10:25 am by Spyridon »
Spyridon
« Reply #110 on: January 16, 2011, 05:43:14 pm »
Joysticks were a bit loose and sloppy so I picked up a set of NOS Wico grommets.  I'll replace the ones in there now and that should tighten things up
WhereEaglesDare
    • My HomePage
« Reply #111 on: January 16, 2011, 07:44:01 pm »
What did you use to mark off the "W" when painting red?  is it some sort of adhesive part of the stensil, i notic it isnt connected to anything
« Reply #112 on: January 16, 2011, 10:21:37 pm »
The stencils are printed on an adhesively backed vinyl. Here's a link to gamestencil's "stencil guide".
WhereEaglesDare
    • My HomePage
« Reply #113 on: January 17, 2011, 07:53:49 am »
yea, I had already read that, its just a little strange.  Never dealt with stencils like that before.
Spyridon
« Reply #114 on: January 27, 2011, 08:37:50 pm »
Finally found some time to install the new grommets.  Here is a comparison between the new and the old:
You can see how the old one was dirty and the rubber was cracked.  Inside the joystick was full of rubber shavings.  Did it make a difference?
Boy did it ever.  On my very first game with the new grommets, I set my high score (I won't tell you what it was because it's not too good)!  The game was in slow motion compared to before.  If you have a Robotron, I highly recommend you replace the grommets.  You won't believe the difference.
« Reply #115 on: January 28, 2011, 02:24:00 pm »
Woah, your old grommets looked pretty bad. The ones I replaced on mine didn't look as worn down, though my cabinet may have had less plays on it.
I replaced them with new ones anyways, and I agree, the joys feel amazing afterward.
Are you going to hang onto this cabinet for much longer? Get your plays in while you can!
Spyridon
« Reply #116 on: January 28, 2011, 03:02:30 pm »
It's mine until the weather breaks.  Will be shipping out in March.
Level42
« Reply #117 on: January 28, 2011, 03:45:45 pm »
 :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy:
TIGHT !!!! LOVE IT !!!!!!
Now....how did that Dutch lightbulb end up in that machine ;)
Spyridon
« Reply #118 on: January 28, 2011, 04:34:45 pm »
Don't worry, I got it out quick and replaced it with one that worked.   ;D
Level42
« Reply #119 on: February 02, 2011, 08:22:36 am »
Harumpffff, god only knows how long it lasted ;) You now got an el-cheapo Chinese surrogate in there ;) ;) ;)
I just installed a fresh new Philips bulb in my Ms.Pac marquee and a Philips starter and miraculously, these are actually still "Made in Holland" !!!!!!!
Felt good.... ;) The marquee looks BRILLIANT now :)
Man I love that Robotron. I could sit half a day and just watch it. If I were there. ;)
