Author Topic: Electricity & surges?  (Read 1298 times)
garnerb350
    • Hyperspin
« on: July 20, 2010, 01:21:48 pm »
I moved my cab into a small trailer...I guess that most trailers have one circurt that runs power throughout the place...
Well my problem is this... My cab is just a PC, Monitor, PC speakers, flouresenct lights for cabs...and all are plugged into a Smartstrip....the smart strip is plugged into the wall...
Now 4 feet away is another receptale with an A/C window unit. I noticed that when the unit turns on..I would see the lights from the marquee flash on and off... kinda of trippy....
Well i went to go play the other day and the lights wouldnt work....so i guess the bulbs blew...but then i noticed that my "on " light for the speakers flashed on....so i went and i turned off the smartstrip when i am not playing....
Can anybody explain this...and any solutions? Has anybody ever encountered this?
bkenobi
Re: Electricity & surges?
« Reply #1 on: July 20, 2010, 01:24:23 pm »
The two are either on the same circuit or they share a neutral wire.  I have the same thing in my house and when the cab turns on, the lights in the room flicker.  The fix is to either rewire or buy a large stock of light bulbs.  I chose to buy more bulbs (~$2 each) rather than rewire (~$2000).   :cheers:
Ed_McCarron
« Reply #2 on: July 20, 2010, 04:14:03 pm »
Yeah, AC compressors are relatively high load devices that can easily cause a brownout.
If you're worried about it, you need to look at putting the cab on a different circuit; and depending on the wiring leading into the panel it may still be an issue.
UPS?  Dunno if an offline ups will help with a dropout that quick, but a line interactive or true online one should smooth it right out.
http://www.newegg.com/Product/Product.aspx?Item=N82E16842107140&cm_re=ups-_-42-107-140-_-Product
This one looks to be line-interactive.  Probably a ferro-resonant transformer to help smooth out variations in mains power.
BobA
  • What Me Worry?
« Reply #3 on: July 20, 2010, 06:31:21 pm »
You might also run a separate circuit to your trailer for your arcade cab.  Depends on if you have access to another circuit in your yard.
