Author Topic: Taito cab knock off W/ Bubble Bobble theme.*Updated March 2nd 2011  (Read 20956 times)
OverRide
  • Last login:Yesterday at 07:57:50 pm
This is my first attempt at a scratch build. My plan is to do Bubble Bobble themed art work on a Taito style cab. I built the cab from rough measurements I found on BYOAC and built it around my WG 25" arcade monitor.
I will add hardware info and other specs tomorrow. In the mean time, here are some pics of my progress this weekend.
Hardware Update:
I acquired a nasty Alien Vs Predator cabinet and used the Monitor and JAMMA harness from it. I wanted to build a JAMMA cab just to have the option.
Monitor: WG K7000. Did a cap kit on it.
P4 3GHz 1GB RAM
Video card: ArcadeVGA AGP
J-PAC JAMMA Interface
Windows XP
Frontend: Hyperspin - Maybe MALA
Controls (from Lizard Lick):
This will be two player 2 button 4-way
Sanwa JLW-UM-8 Joystick x2
Happ Comp buttons
Colour Scheme:
Orange cab with white t-molding
Side cut out with T-Molding slotted.
Update: Fixed broken links
« Last Edit: March 02, 2011, 10:15:59 am by OverRide »
dawolv
  • Last login:March 25, 2016, 08:23:21 am
Re: Taito cab knock off W/ Bubble Bobble theme.
« Reply #1 on: July 18, 2010, 11:27:28 pm »
Looking good, it looks like you are using french cleats to hang the back?
OverRide
« Reply #2 on: July 18, 2010, 11:37:12 pm »
Thanks.
I think it's a crude version of french cleats. The method for hanging the back door I stole from my Nintendo DK cabinet (My next project). I was going to hang the door with a hinge, but I figured doing this to be a lot simpler and in the end it will make the back of the cab more accessible(the 5/8" plywood is light enough to easily lift out not having to pull it to far from the wall). I will use a small latch on the outside at the top to keep it from falling back.
gavkiwi
  • Last login:October 12, 2021, 08:42:07 pm
  • 'I am from a Land Down Under'
« Reply #3 on: July 23, 2010, 10:21:12 am »
OverRide, Bubble Bobble is my favorite game of all time, I would love to undertake a project like this, I am looking forward to your updates, looks great soo far!
OverRide
« Reply #4 on: July 27, 2010, 10:17:34 am »
Thanks Gav. Bubble Bobble is by far my favourite game too. It was at a doughnut shop for years, just around the corner from where I grew up. I plan to add some more photos and hardware info updates tonight or tomorrow. I hope to have it playable/testing by the weekend. I am a little nervous about the angled control panel and monitor and comfortability.
gavkiwi
« Reply #5 on: August 07, 2010, 10:51:07 am »
Any updates ?
OverRide
« Reply #6 on: August 07, 2010, 01:59:09 pm »
I have been a slacker about the updates. All my free time has been spent working on the cab.
Here are some photo updates. Most all are self explanatory. I have since disassembled the guts of the cab and am still trying to come up with a solution for mounting the smoked plexi (See last photo). What I really want is to have the plexi flush with the CP. If I use the solution in the last photo then there would be a 1" piece of wood butted up against the CP and it would make taking the monitor out even harder. Not that this would look bad, i just think it would look better with the plexy flush on the CP. There will be an artwork bezel adhered to the top of the smoke plexy which would hide any screws, allowing me to mount it to a wood frame and then mount the wood frame to the cab, making it removable for easy access to the monitor.
note: There are clamps holding the CP/front door secure. They are just not in any of the photos.
Above image: monitor was a complete pain in the ass to get in but for the most part slid into place.
Above Image: Testing it out. Played for a hour or so, sitting and standing. My hands and neck felt fine so I think I am happy with the angles and orientation.
Above image: top left button is PC power and under it is the main kill switch. Top right button is the shift button for the j-pac.
Updated broken links
« Last Edit: March 02, 2011, 10:10:51 am by OverRide »
YoGaBaR
  • Yeah im in the club
Re: Taito cab knock off W/ Bubble Bobble theme.*Updated Aug 7th 2010
« Reply #7 on: August 07, 2010, 07:55:52 pm »
Looking Great!! Good to see another Bubble Bobble fan! Have you thought about artwork?
Check out my bubble bobble machine as well! Link in the footer!
OverRide
« Reply #8 on: August 07, 2010, 09:01:13 pm »
Thanks YoGa. I don't know how I missed your Bubble Bobble machine! That thing is sweet.
I have a few ideas rolling around in my head as to how I will do the artwork. The side will be orange and the t-molding is white. I was thinking some big bubbles with enemy's in them on the sides. I may or may not put the Bubble Bobble logo on the side. And I plan to slightly modify the existing bubble bobble marquee to match my colour scheme.
Not until I see some of it on paper will I know for sure.
OverRide
Re: Taito cab knock off W/ Bubble Bobble theme.*Updated March 2nd 2011
« Reply #9 on: March 02, 2011, 09:56:44 am »
Well it's been about 7 months since my last update. I promised myself I wasn't gonna be that guy and leave a dead project thread. Life and delays got in the way. My Wife and I have our first baby coming this month, I had to re-certify for a Cisco Professional exam (lots of studying) and the art work for the cabinet took a few tries for the printer, plus my graphics that I designed in inksacpe needed to be reworked for their in house applications.
Now that I have the artwork in hand, things are back on track.
My preggers wife and I applied the artwork last night to the sides, marquee and bezel.
My next steps are to
 Touch up the black paint on the inside of the cabinet. The monitor installation left some scratches.
 Install the t-molding
 Apply control panel/front artwork
 Install hardware
 Play!
Testing out the marquee:
Bezel applied to the smoked plexi with the center carefully cutout:
Side art applied and trimmed. I am very happy with the results:
Had to test out the marquee with the light on :)  (There is small slit on the left side of light getting through. I will have to come up with a way to fix that).
mgb
  • North East, US
« Reply #10 on: March 02, 2011, 12:44:29 pm »
very nice. I'm liking it and looking forward to seeing finished pics
  • Last login:December 19, 2025, 08:07:01 am
« Reply #11 on: March 02, 2011, 12:49:45 pm »
Looks great with that big monitor in there - did you have to modify the original dimensions to get it to fit?  I have an actual Taito and I'm trying to figure out the largest CRT I can squeeze in there without it hanging out of the back...
OverRide
« Reply #12 on: March 02, 2011, 03:34:01 pm »
I built this one from scratch with the 25" monitor in mind (its a tight squeeze). I'm not sure what an original Taito would fit with out modification.
OverRide
Re: Taito cab knock off W/ Bubble Bobble theme.*Finished!
« Reply #13 on: March 03, 2011, 09:00:55 pm »
Well, the cabinet is pretty much finished. I have a few odds and ends to finish up, but not more then a couple hours of work max.
Anyways, here is the finished product (note. I will be fixing the the marquee light getting through to the monitor).
Let me know what you think. Not that I can change much at this point.  ;)
Thanks BYOAC for all the help! I always managed to find or get an answer to all my questions.
mgb
  • North East, US
« Reply #14 on: March 03, 2011, 10:11:38 pm »
Hey OverRide,
 Your cabinet looks great. Great idea going with Bubble Bobble theme.
How is it on the wheels, Stable, easy to move when wanted?
« Last Edit: March 04, 2011, 06:30:21 pm by mgb »
bleargh
  • Last login:December 30, 2025, 06:03:24 pm
  • ribbit...
« Reply #15 on: March 04, 2011, 12:03:23 am »
Nice looking cab there.  Cute theme, and well executed!   :applaud:
borals
  • Last login:March 07, 2020, 05:51:14 am
« Reply #16 on: March 04, 2011, 02:58:34 am »
That is damn nice!
Love the theme, great work  :applaud:
dextercf
  • [thisispersonal]
« Reply #17 on: March 04, 2011, 08:59:32 am »
Doesn't this generate alot of heat?
I would go for some LED coverted bulbs atleast..
Other than that, pretty cool cabinet!
Also, the car next to it... nice!
OverRide
« Reply #18 on: March 04, 2011, 11:00:15 am »
I was thinking that as well. I don't want to melt the vinyl of the marquee. I have a fan in the top exhausting the warm air, which is thermally controlled. I will play it by ear though. If the fan is on a lot then I will put in LED's. The lamps came with the cab I gutted for the wiring harness and monitor, made things easy. Plus I do like the warm glow from the incandescent bulbs.
Rando
« Reply #19 on: March 04, 2011, 04:03:16 pm »
Um,
Since no one has asked... What's the CAR in the background?  Thought it was a Cougar at first but more recent pic looks like a Skylark or something.  Looks to be in great shape, I like the color and vinyl top.  Not to hijack but I've got a '71 Mustang in my garage so I tend to get excited when I see something like that just sitting there and ignored!  ;D
OverRide
« Reply #20 on: March 04, 2011, 04:18:20 pm »
Thanks! It is a 72 Cutlass. 350 4bbl, duals. Pretty much stock otherwise.
It does need paint. It looks nice in photos but up close it shows. The interior is mint as is the engine bay.
Looking forward to spring time to get it back out on the road! Play some bubble bobble then go for a cruze! :P
gavkiwi
« Reply #21 on: March 14, 2011, 09:54:52 am »
Looks fantastic, I'm very jealous here. Anyways welldone  :applaud:!
« Reply #22 on: March 14, 2011, 10:09:30 am »
Holy bananas dude - friggin AWESOME.  I love the art!   :cheers:
OverRide
« Reply #23 on: March 17, 2011, 03:52:24 pm »
Thanks for the kind words. Been having a blast playing it, has been 15+ years since I played bubble bobble and wonder boy on an arcade cabinet and cant get enough. :)
Already thinking about my next project(s).
push2reject
  • Last login:January 28, 2014, 06:55:40 pm
« Reply #24 on: March 18, 2011, 01:23:11 am »
Wow, thats a great looking cab!  I think Bubble Bobble is an underrated game.  I love playing 2-player.  It aways turns to good natured trash-talking when a player start stealing power-ups the the other one earned.
On the other side of the screen, it all looks so easy.  -Kevin Flynn
mgb
  • North East, US
« Reply #25 on: March 18, 2011, 09:08:20 am »
Bubble Bobble is the only game my wife will really play on my cab.
sistemika
  • Newbie
  • Last login:February 20, 2013, 05:57:27 pm
« Reply #26 on: February 20, 2013, 04:12:16 pm »
Great Cab... Wonderfull.
I want to build a cabinet for my kid, and a like so much your cab. Do you have the plans?
Thanks a lot!!
OverRide
« Reply #27 on: February 20, 2013, 04:36:36 pm »
Thank you! Unfortunately I don't have any official plans.  I built this cab before I was comfortable with software like sketchup so nothing but the artwork is documented. I found some rough dimensions for this type of Taito cab (a search on byoac will garner the same info) and built it around the monitor.
Good luck. PM me if you have any questions you think I can answer.
b3nfy
  • Last login:December 08, 2017, 05:38:23 am
« Reply #28 on: December 07, 2017, 10:03:35 am »
Hello everyone!
I'm actually in love of that graphic, and in this time i'm working on a cabiet for my jamma collection...
Where can I find that graphic? it's absolutely amazing!
wheeezy
  • Last login:June 12, 2019, 10:51:36 am
« Reply #29 on: December 15, 2017, 04:35:47 pm »
same here
great graphic
OverRide
« Reply #30 on: December 15, 2017, 06:48:41 pm »
Thanks guys. I get hit up for the files a few times a year. I am going to post them somewhere public and provide a link here tonight.
OverRide
« Reply #31 on: December 15, 2017, 07:13:49 pm »
URL to download art files in various formats. It has been a while, but I think this is all anyone would need to get the art printed.
https://drive.google.com/open?id=1NX6GuzlBJry1i7MdSVATMp05oZcLBhU7
