Author Topic: Converting Laptop Power Button  (Read 1234 times)
Spyhunter2010
  • Last login:July 25, 2010, 06:42:36 am
« on: July 18, 2010, 01:35:08 pm »
I recently bought an older laptop from ebay (HP Model: NX 6125) and want to make a HTPC PC from it.  I have everything under control apart from the power on button.  It plugins into the motherboard using 4 pin plug (red, white, white, black) - is there anyway I can use these wires to use a normal power button (2 connectors) in any way please?  or buyl a different power button for me to fit/use?
Bender
Re: Converting Laptop Power Button
« Reply #1 on: July 18, 2010, 02:48:59 pm »
I believe you can but you lose the hibernation /sleep functions of the button
Just use a multi-meter to see which two leads to use
I hat to actually connect to the button itself and one of the four side leads (took me some time to work that out)
this was on a dell XPS 1530
« Last Edit: July 18, 2010, 02:56:11 pm by Bender »
Spyhunter2010
« Reply #2 on: July 18, 2010, 06:06:13 pm »
you mean 1 of the four leads AND to the button board?
Bender
« Reply #3 on: July 18, 2010, 06:33:12 pm »
yes, just like in the picture, 1 of the four leads and the metal button housing
but make sure you test it with a multi-meter to be sure yours might be different
« Last Edit: July 18, 2010, 06:34:57 pm by Bender »
Spyhunter2010
« Reply #4 on: July 19, 2010, 09:54:14 am »
i'm going to sound dumb here but do you mean a normal electrical multi tester?
If so, how would i use - they look very complicated.. or is that just me LOL
