Author Topic: Request: Toggle for gamelist visibility  (Read 2945 times)
jimmy2x2x
« on: July 10, 2010, 02:22:12 am »
Would it be possible to have a switch per gamelist to disable each one?
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: Request: Toggle for gamelist visibility
« Reply #1 on: July 10, 2010, 02:36:15 am »
BY disable do you mean like 'skip it' when you use controllers or for it not to appear in the list when you right click?
jimmy2x2x
« Reply #2 on: July 10, 2010, 02:40:38 am »
Skip it when using the controller
loadman
  • Moderator
    • MaLa
« Reply #3 on: July 10, 2010, 02:50:18 am »
Visa or AMEX sir?
Just kidding  :laugh2:
I will put on list as it sounds easy enough and sounds like it would not break anything else
jimmy2x2x
« Reply #4 on: July 10, 2010, 02:56:54 am »
Many thanks, kind sir!
Cheque is in the post  :cheers:
jimmy2x2x
« Reply #5 on: August 01, 2010, 03:11:30 pm »
Hope you got you cheque ;)
I was wondering you you could add another 2 toggles to the gamelists!
Sorry about the requests, but I think they will improve your already excellent FE
For each gamelist, would this be possible:
Toggle for visability
Toggle for vertical mode visability
Toggle for horizontal mode visability
For someone like me who rotates their monitor, this would be great as I could now hide mastergame lists for guests, and also hide the wrong orientation lists (for example hide daphne when im in vertical mode)
Thank you for all your hard work and dedication Loadman!
