Author Topic: Aim Trak Mame setup  (Read 2580 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
Aim Trak Mame setup
« on: July 05, 2010, 04:59:48 pm »
Can someone refresh my memory how to set up the Aim Trak in Mame.  I got it recognized as a mouse in windows, I set up multi-mice in Mame, and I set up the lightgun to equal the mouse.  I went into the in-game menu and it always says 'mouse 1'.  My regular mouse works but not the Aim Trak mouse...I know I am missing something easy in Mame......what is it???
Thanks....
Cananas
  • Last login:August 27, 2017, 07:39:03 am
  • and the seventh day... PacMan was created
Re: Aim Trak Mame setup
« Reply #1 on: July 05, 2010, 06:07:18 pm »
Edit this settings in mame.ini:
To enable the Aimtrak (one, two or more):
Code: [Select]
lightgun 1
If you are using the Aimtrak GP Buttons:
Code: [Select]
joystick 1
If you are configured shooting offscreen to mouse right in the Aimtrak config utility:
Code: [Select]
offscreen_reload 1
Now remap the control lightgun x & Y axes to match your Aimtrak.
There is no need to enable multimouse and mouse to use the Aimtrak.
« Last Edit: July 05, 2010, 06:08:49 pm by Cananas »
