Author Topic: Kortek KT-1420A (KI-2-VO) Shutting Down  (Read 2660 times)
korendog
  • Last login:May 05, 2011, 03:24:14 pm
  • The squeaky wheels gets the grease!
« on: July 03, 2010, 08:05:19 pm »
This monitor powers up and I get a picture for about 10 to 20 seconds and then the monitor shuts off.  The picture looks fine other than it seems to have a slight wave in the picture.  Does anyone have any thoughts on what to check/replace to rectify this?
Capcom Bowling, Star Wars (Cockpit), Karate Champ, MAME (Vertical)
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Kortek KT-1420A (KI-2-VO) Shutting Down
« Reply #1 on: July 04, 2010, 10:29:50 pm »
without seeing a schematic, a visual inspection is warranted .
look for domed /leaking caps , burn marks, poor solder connections , etc....
since there is a "wave" , i'm betting a *linear regulator type pwr suply .
thus, a weak/bad filter cap there is a possibility  .
could also be a faulty decoupling cap in the Hosc circuitry - i.e. may cause Horizontal instability
* requires an isolation xformer
korendog
« Reply #2 on: July 06, 2010, 06:55:58 pm »
Thanks for the reply qrz.  I didn't see any bad/leaking caps but I did a cap kit anyway and it didn't change anything.  I'm guessing the filter cap is the gigantic black one behind the flyback.  Is there a way to test this or should I just order up a replacement and put a new one in?  Ken Layton sent me a copy of his repair guide for this chassis with a list of components to check.  I will have to do some homework to figure out how to test all these though as I as don't have a lot of experience in electronics. -Jarrett
