Author Topic: K7400 horizontal sync issue?  (Read 1659 times)
newmanfamilyvlogs
    • Newman Family Vlogs
« on: June 29, 2010, 10:50:46 am »
K7400, GeForce 2 MX 400 running under Soft15Khz
Would this be caused by the monitor, or the signal being sent to it?
newmanfamilyvlogs
Re: K7400 horizontal sync issue?
« Reply #1 on: June 30, 2010, 10:29:42 am »
I'm guessing it must be the monitor; I hooked the same video signal up to a K7000 I have and although the chassis is in desperate need of a capkit and probably a new flyback, I didn't see any of the same twitching.
So now what?
« Reply #2 on: July 01, 2010, 01:08:43 am »
Now you take a video and post it so we know what your talking about. Even a pic with a discription would be helpfull.
Unfortunatly modern technology hasn't given me the ability to read minds and see the twitchiness.
Also have you re-capped this monitor. If not I suggest you do it, since by this time, the monitor is many years old and probably in dire need of a cap-kit.
newmanfamilyvlogs
« Reply #3 on: July 01, 2010, 06:20:44 am »
I posted a video in the first link. It displays for me. Did I embed it wrong?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #4 on: July 04, 2010, 11:12:29 pm »
just for the sake of argument , check/replace c706,709.
« Reply #5 on: July 05, 2010, 02:04:15 am »
+1 for c706 & c709.
you may be picking up some noise in the sync line. be sure the wires are not running next to any high voltage wires or the power running around the cab. try to keep them a short as (within reason) possible.
