Author Topic: What Wood To Use  (Read 2366 times)
Darren01274
  • Last login:September 12, 2020, 10:05:08 am
What Wood To Use
« on: June 21, 2010, 07:12:03 am »
Hi I am going to make a Cocktail Cabinet and thought about using Black MDF so I did not have to paint it, seems you can no longer get Black MDF. What is the best wood to use and what
is the best paint etc to use.
  • Last login:February 22, 2026, 06:49:16 pm
Re: What Wood To Use
« Reply #1 on: June 21, 2010, 12:11:26 pm »
If you want that "Black MDF" look, you can buy MDF, laminate it yourself with some black laminate, and go from there.
Darren01274
« Reply #2 on: June 21, 2010, 01:48:46 pm »
If I wanted to paint it what is the best paint to use and is it easier than the laminating option
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #3 on: June 22, 2010, 05:23:15 pm »
is used 16 mm black mdf for a bartop project . i clear coated every part of it with acryl paint . the advantage is u dont need much painting nor t molding . the appearance isnt 120 % ultradark black , coz " black " mdf usually has some brighter i would call em microscopic dropouts. colored mdf is available in red , green , yellow, blue and more. i advise clear coating with professionell car paint. unpainted mdf looks more like grey than black.
for bartop or cocktail purpose its no bad choice at all , but a fullsizer would be a little 2 expensive.
« Last Edit: June 22, 2010, 05:34:45 pm by apfelanni »
