Author Topic: Case fans......  (Read 2560 times)
reptileink
  • An 8 bit hero
Case fans......
« on: June 17, 2010, 04:16:13 pm »
How do you have yours running? Do they come on when you power up the unit, or do you have a thermo control for them? Also, I know most run on  12v, should I just hunt for a CPU power supply to plug into my strip?
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
Re: Case fans......
« Reply #1 on: June 17, 2010, 05:21:38 pm »
Or cut the end off an AC adapter and splice  ;D
I got several things running this way including a case fan
Im also using a smartstrip so everything comes on when the pc powers up
My MAME Build:
reptileink
  • An 8 bit hero
Re: Case fans......
« Reply #2 on: June 17, 2010, 05:27:38 pm »
Good idea. I figured I could do that, but always good to have an opinion. Can I run two fans off one adapter?
Smeghead
    • MY MAME BUILDS
Re: Case fans......
« Reply #3 on: June 17, 2010, 05:51:06 pm »
Im kinda new to this so others please chime in, but im running 3 coinslot lights, the LED for the trackball and a 5" case fan off mine!  (12v 1000ma)
My MAME Build:
92greenyj
  • Last login:January 02, 2012, 06:19:41 pm
Re: Case fans......
« Reply #4 on: June 17, 2010, 09:20:57 pm »
I was planning to just leave the side panel off my computer tower and running my cabinet fans right off the computers internal ATX power supply
orchidius
  • Last login:January 30, 2013, 12:44:11 pm
Re: Case fans......
« Reply #5 on: June 18, 2010, 05:20:56 am »
You could just go the easy way with the fans too... They come with a molex plug, use that one with your PC powersupply!!
reptileink
  • An 8 bit hero
Re: Case fans......
« Reply #6 on: June 18, 2010, 09:33:43 am »
I'm using an orignal Xbox, not a PC.....
92greenyj
Re: Case fans......
« Reply #7 on: June 18, 2010, 01:38:39 pm »
ok, so get a cheap ATX power supply. u can find them for less than 20 bucks. jump two wires together to make it turn on and run without motherboard input and you are good to go
gryhnd
Re: Case fans......
« Reply #8 on: June 18, 2010, 02:35:10 pm »
The fans will have a mAmp listing on them somewhere. Add the two up, and use a 12V wallwart/power supply of equal or greater value. Probably not hard to do at all if only two fans.
I don't see the value of buying an AT/ATX PSU for only two fans.
Completed: No Name Upright
Zebidee
  • Last login:Yesterday at 09:46:52 pm
Re: Case fans......
« Reply #9 on: June 19, 2010, 08:43:52 am »
PC power supplies should have a 'load' (ie a motherboard) attached in order to work properly & sustainably. There are ways to trick this load, but Gryhnd is right -  it is all fussy compared to getting a 12v wall-wart from your favourite cheap supplier (you might even find that you have a spare one lying around).
On the other hand, you can probably also tap into the 12v on your xbox if you are clever about it.
« Last Edit: June 19, 2010, 10:17:04 am by Zebidee »
reptileink
  • An 8 bit hero
Re: Case fans......
« Reply #10 on: June 19, 2010, 09:15:19 am »
Yeaaahh, I think I'll just go with the wall wart. My wife has a box of them laying around somewhere(she saves EVERYTHING!)  Split em off, and wire up the fans. When I hit the smart strip, everything will turn on....bingo boingo.
Ed_McCarron
Re: Case fans......
« Reply #11 on: June 19, 2010, 09:23:13 am »
And here I am, reading the thread title and thinking "Yeah, I'm a fan of cases..."   :dizzy:
Wallwarts are easy - just make sure they provide enough current so they don't run hot and burn up.
