Author Topic: think my Duck-san 29" just died?  (Read 1806 times)
mh12
  • Last login:December 24, 2010, 10:03:57 am
« on: June 10, 2010, 10:30:20 pm »
i think the monitor grantspain helped me ID here: http://forum.arcadecontrols.com/index.php?topic=87135.0
just died! the picture went fuzzy and i started hearing, i guess, static, and i shut off the power bar. trying an hour later, the monitor doesn't power up at all. and there's a strange smell lingering in the room, so i opened up all the windows..
is there any way to save this or is it dead? i have no idea where i'd find a replacement. but at least i'm in Toronto now (and this didn't happen after i move to a smaller place in a few months)
 :badmood:
« Last Edit: June 10, 2010, 10:32:11 pm by mh12 »
grantspain
Re: think my Duck-san 29" just died?
« Reply #1 on: June 11, 2010, 07:12:14 am »
sounds like the flyback is toast
if you have access to a inductance meter you can check the inductance and impedence of the yoke and then match a replacement chassis
mh12
« Reply #2 on: June 11, 2010, 07:58:03 am »
thanks again, grant. but i'm pretty clueless with this stuff. time to start seeing who in the area could help out with this.
ETA: by the way, is it OK to use my LCD computer monitor until I fix this CRT/get a new one? My *only* video card is the ArcadeVGA - can that do any damage to a normal PC monitor?
« Last Edit: June 11, 2010, 09:46:20 am by mh12 »
grantspain
« Reply #3 on: June 11, 2010, 12:00:36 pm »
any monitor will work,your ducksan is vga so any lcd or pc monitor will work without issue
the only times you can issues is when you feed vga/svga into a cga monitor-sometimes the HOT fries
