Author Topic: Marquee too bright -- annoys the hell out of me!  (Read 3578 times)
Justin
  • Last login:November 25, 2025, 10:20:05 pm
    • Centipede MAME cabinet
« on: August 02, 2003, 12:16:36 am »
I'm using an original Centipede cabinet, and I like playing in the dark. Now...
I am a little over 6 feet tall, and the marquee is almost in front of my face when I play standing up (which I normally do).  I just realized cabs must have been designed for 12-14 year old kids...?  I certainly don't remember marquees been this 'low'!
I have resorted to switching off the marquee lamp, because the light shines on my face, and doesn't let me see the monitor/gameplay very well.  Has anyone else experienced this?  Can the lamp be dimmed?  I have already put a diffuser on top of the tube -- didn't help much.
P.S:  All tubes I have seen are 15 Watts.
"3 warps to Uranus" -- so I stopped playing!
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
Re:Marquee too bright -- annoys the hell out of me!
« Reply #1 on: August 02, 2003, 12:27:28 am »
Try putting some light-colored construction paper behind the marquee.  Florescent lights themselves don't respond well to dimming.
kspiff
  • Last login:February 02, 2016, 09:15:36 pm
  • Love of the game, baby.. love of the game..
« Reply #2 on: August 02, 2003, 08:05:23 am »
Most older, stock/original games had lower watt bulbs as well.. over time most vendors and operators replaced them with the standard, readily available 15-watt (I may be up for doing the same soon -- screw having bulbs shipped :/).
k-spiff
ErikRuud
« Reply #3 on: August 02, 2003, 09:33:12 am »
The cubicles where I work have dimmers on the florescent bulbs.  they are clear plastic tubes with a 50% to 80% screen printed on them.  as you rotate the bulb it cut out more of the light.
If you have access to a laser printer and some transparency film, you could print a 50% - 80% (med to dark gray) screen and use that to dim your bulb.
American Laser Games Wrapper
O2em Rom Utility
Justin
« Reply #4 on: August 02, 2003, 09:58:49 am »
I'm looking at the original Centipede manual... the parts listspecifies for the fluorescent bulb:
Part No.  70-304 :  18-inch 15 Watt Cool White Fluorescent Tube
So, it seems like 15 Watt is correct... perhaps the original marquee was a lot darker?  ???
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #5 on: August 02, 2003, 12:46:55 pm »
Put a piece of white tagboard behind your marquee so not as much light gets through.  Cut the tagboard to the same size as the marquee.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #6 on: August 02, 2003, 03:00:43 pm »
Maybe you could buy some DIY window tinting film (or something similar), and wrap that around the tube.  That should cut the brightness way down.  You could wrap it several times until it's as dark as you like.
My other job...
  • Last login:Today at 05:05:50 am
« Reply #7 on: August 03, 2003, 03:19:29 am »
Not a good idea 1up as most tinting materials are flammable or at least meltable.  ;)
spidermonkey
  • Last login:October 01, 2023, 04:15:59 am
  • Bombjack junkie
« Reply #8 on: August 03, 2003, 04:07:42 am »
Sniff sniff... mmm whats cookin ?  Flamb'e ala marquee. :o :o Sir.. perhaps you'd  like a glass of gasoline to wash it down with ?  ;)
"Sinistar has bad breath"
crsdawg
  • Last login:September 13, 2019, 06:10:05 am
  • I plan to live forever, or die trying.
« Reply #9 on: August 03, 2003, 04:10:12 am »
if he has his marquee in a plexi sandwich he could put the tinting on the inner facing plexi piece.
    • GroovyGameGear.com
« Reply #10 on: August 03, 2003, 10:41:33 am »
Another option....
Get a thin piece of clear acrylic and some white spray paint.
Step 1:  Lay down a light, even coat of paint on the acrylic.
Step 2:  Let dry and place between the light and the marquee.
Step 3: If still too bright, goto Step 1.
Not "high tech" but it should work.
Justin
« Reply #11 on: August 03, 2003, 11:25:22 am »
OK, I cannot sandwich anything between my marquee plexi sheets, because the printed marquee is 'stuck' on to the rear plexi:
==============  <--Plexi
----------------------  <--Marquee sticker (stuck to plexi)
=00000000000000= <--Bulb
I resorted to putting some white packing paper on the rear, and now all looks good:
----------------------  <--Paper
1UP
  • Token Junkie
    • 1UPArcade
« Reply #12 on: August 03, 2003, 03:30:10 pm »
Hey, how about a sheet of 1/16" smoked plexi behind your entire marquee?  That would be rigid, and dim things down a lot without melting down!
BTW, if automotive window tinting wouldn't combust on the windows of a car in summer heat over 110o, I doubt it would flame up or melt on a fluorescent bulb that's usually cool enough to touch.  Ever notice how most fluorescent fixtures these days are plastic?
« Last Edit: August 03, 2003, 03:34:50 pm by 1UP »
My other job...
Justin
« Reply #13 on: August 03, 2003, 05:16:14 pm »
Fluorescent bulbs are cold bulbs...  eat is not a problem with these AFAIK.   Doesn't worry me!
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #14 on: August 04, 2003, 04:12:29 pm »
light without heat?! that's amazing!
rampy
Justin
« Reply #15 on: August 04, 2003, 06:02:11 pm »
Well, OK, so they aren't COLD.  But they are certainly colder than normal incadescent bulbs.  :)
Do LEDs emit heat BTW?   ???
AlanS17
    • AlanS17
« Reply #16 on: August 04, 2003, 06:05:39 pm »
They do, but very little.
Justin
« Reply #17 on: August 04, 2003, 06:14:13 pm »
OK, but a little google searching and I came up with this:
Reactions that produce light without heat are called chemiluminescent reactions. Perhaps the most familiar chemiluminescent reactions are those that occur in living organisms. Fireflies produce light without heat by a chemiluminescent reaction. Chemiluminescent reactions that occur in living organisms are called bioluminescent reactions.
Light sticks sold at many stores produce light without heat through a chemiluminescent reaction.
 :o
Zakk
  • Last login:Yesterday at 10:58:06 am
« Reply #18 on: August 04, 2003, 07:44:03 pm »
Wonder if that's the idea behind organic-display car decks?  I mean, it might be based on chemiluminescent theory, although I'd like to know how they control it.
Or.....just another spiffy brand name marketing scheme?  I'm off to Best buy to lick the organic diplay decks!  Let's see if they give off heat! Yum!
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #19 on: August 04, 2003, 08:21:56 pm »
What I did was just to print out a second print of my marquee and layered them.  The color was brighter, the light was dimmer, and the games played better.  :D
