Author Topic: MaLa Errors  (Read 2291 times)
Onyx_PghPA
  • Last login:January 20, 2011, 06:03:02 pm
MaLa Errors
« on: June 09, 2010, 08:57:14 pm »
Having two problems with MaLa; after spending weeks finally fixing all of my other emulation problems.
1)  It seems whenever I exit a game using ESC (either the ESC button on a keyboard or the control panel button I have programmed for ESC), I get an error message:
http://www.flickr.com/photos/pctech714/4686280823/#
2)  Whenever I first load MaLa, have DAPHNE selected as my emulator and right-click and select options, a bunch of error messages pop up:
http://www.flickr.com/photos/pctech714/4686932782/#
Anyway, anybody encounter these problems and know of a solution.  #2 is fairly minor -- I know just to avoid making changes to options in DAPHNE, but the first one kinda sucks.
Thanks,
Joe
My arcade cabinet hardware:
MSI K9N6PGM2-V motherboard (onboard video and 10/100 networking)
AMD 64 X2 4800+ CPU
2GB DDR2 800 RAM
16GB solid state hard drive
27" D9800 Wells Gardner arcade monitor
Windows 7 Ultimate 32-bit
MaLa and Ultramap are on the cabinet's hard drive, but the emulators, ROMs, etc. are all on a shared network drive on my server PC.  Control of the cabinet (for making changes and so forth) is done through PC Anywhere, so I don't need a keyboard or mouse.
« Last Edit: June 10, 2010, 10:40:45 am by Onyx_PghPA »
"mmmmm...control panel finished... <drool>"
lcddream
  • Last login:December 04, 2024, 03:59:31 pm
  • Say goodbye to gravity...
Re: MaLa Errors
« Reply #1 on: June 11, 2010, 12:30:42 pm »
loadman
    • MaLa
Re: MaLa Errors
« Reply #2 on: June 11, 2010, 09:44:25 pm »
psssssst
http://forum.arcadecontrols.com/index.php/board,43.0.html
Indeed
What version of mame are you running? I always recommend using a command line version of mame.
Onyx_PghPA
Re: MaLa Errors
« Reply #3 on: June 13, 2010, 10:38:02 am »
Yes, I'm using a command-line version of MAME (v0.138).
Onyx_PghPA
Re: MaLa Errors
« Reply #4 on: June 16, 2010, 10:55:48 pm »
psssssst
And for the record, if someone could move this post to the MaLa forum (of which I was not aware), I'd be most appreciative.  Not sure who does that, but Mr. Saint, if you're there, maybe it will help me to get an answer!  :)
