Author Topic: XBOX 360 and WG D9800  (Read 2008 times)
ei8ht
  • Last login:January 02, 2023, 03:20:47 am
« on: June 08, 2010, 08:49:14 am »
Hi,
is it possible to use an Xbox 360 with an Wells Gardner D9800? I know that the xbox uses a higher resolution but maybe there is a way...
ei8ht
Jack Burton
Re: XBOX 360 and WG D9800
« Reply #1 on: June 08, 2010, 10:54:45 am »
Yes you can.
All you will need to do is buy an Xbox 360 VGA cable and connect it to the monitor's VGA input.
The highest resolution you will be able to play games in will be 480p.  I'm not certain that this monitor will accept or be able to display 1080i.  But it will still look really good in 480p.
