Author Topic: S-Video & A Good Res  (Read 1617 times)
Unkis17
  • Last login:March 24, 2017, 12:03:37 am
  • I'd keep on building if i had the space
« on: August 01, 2003, 02:37:43 pm »
I am currently running my EMUs through my 36" Widescreen HDTV and i was wondering what type of res looks good for EMUs?  I am using s-video.  When i orginally plugged in, the res for the video card was outputting 1024x768, but that is way too tiny a font to read on the TV.  I downed to 800x600 and that is ok (thinking of changing the MameWah Font Size).  Although with Mame.ini resolution = auto some games don't play (specifically older vertial games, they are only half on the screen).  By setting the games to a specific res of 640x480 the games correct themselves.  Should i run everything at 640x480?  Will this make newer games like Motral Kombat and Marvel Vs Capcom look like crap?  Or should i just manually edit ini files for certain games?
Thanks for the help.
StephenH
Re:S-Video & A Good Res
« Reply #1 on: August 03, 2003, 03:19:25 am »
Actually, most games use a resolution LOWER than 640x480 natively.   Common resolutions for games are 256x224, 320x240, and some even lower.   Even Marvel vs Capcom I think uses 384x224.
You could use 640x480, or you can try even lower.
