Author Topic: Dead chassis, what is this component?  (Read 2420 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: May 26, 2010, 08:00:01 am »
Hey all!
I have this Min Dong 25-29" chassis, that have what looks like a burned transistor:
As you can see in the pics there's burned around the legs...the transistor doesn't have any name
on it...and I DID remove the cooling-metal thingy:)
I would really like to know what it is, since it probably needs replacing(?) :dunno
Thanks!!
Nicholas
  • Last login:November 26, 2025, 03:26:23 pm
Re: Dead chassis, what is this component?
« Reply #1 on: May 26, 2010, 11:24:22 am »
it looks like it might be the MOSFET for the main power supply. not sure 100% though.
if the chassis dead, it might be. Check to see if one of the legs of it connects to a little 8 pin microchip (probably an KA3842) if it does that what it is, you will have to remove the MOSFET and get a replacement.
take note though, often with the replacements you will have to isolate the MOSFET metal backing from the metal of the heatsink or you will blow it the first second you power it. The replacement should come with a grey silicone rubber or a clear plastic LOOKING (its actually thin crystalline silica)  insulator. if the replacement doesn't come with one, and the original part didn't come with one, then don't worry about it. just a FYI.
AE35
« Reply #2 on: May 26, 2010, 11:32:05 am »
Thanks for your reply!
There's no 8-leg chip anywhere on the board:)
By the way, it has 5 legs. If it is the MOSFET, any idea what a replacement could be called?
Thanks!!
Nicholas
AE35
« Reply #3 on: May 26, 2010, 12:28:51 pm »
Oh, the other one attached to the heatsink on picture 2(left), is a Toshiba C5339...(with 3 legs)
grantspain
« Reply #4 on: May 26, 2010, 05:17:16 pm »
i am working that exact chassis tomorrow,its a power regulator IC-I will get you the part number tomorrow
the 2sc5339 is the HOT
grantspain
« Reply #5 on: May 27, 2010, 08:00:07 am »
AE35
« Reply #6 on: May 27, 2010, 08:08:20 am »
Thanks, very nice of you. I can always count on you for my monitor problems:)
Can you give me any advice where to get it? There's not even one on ebay :)
grantspain
« Reply #8 on: May 28, 2010, 01:43:06 am »
sorry i couldn't tell by the angle of the photo. it looked about right for a MOSFET.
what you got there, it's basically a MOSFET and the KA3842 chip jammed into one component.
thank {the guy upstairs if you so believe} for modern technology!
