Author Topic: T-molding trouble  (Read 2305 times)
pepsidx20
  • Last login:August 19, 2014, 06:00:01 pm
  • I'm a llama killer!
T-molding trouble
« on: July 31, 2003, 08:16:24 pm »
Hey folks,
  I've been trying to put in my t-molding.  But the groove where the molding goes is really worn,so it keeps popping out. Any suggestions on how to keep it in there? Other than using glue.
paigeoliver
  • Awesome face!
Re:T-molding trouble
« Reply #1 on: July 31, 2003, 08:18:07 pm »
I always end up using small nails to hold the t-molding in on older worn out cabs.
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #2 on: July 31, 2003, 08:20:12 pm »
I think glue is your only hope.  People have used hot glue guns, I assume a crazy glue would be good.  The only other things I can think of I wouldn't do myself:
1)  Nail/staple it in (that has to look ugly unoess you get nails the same color as the molding?)
2) If you could somehow wedge paper over the part that goes in the slot, then push it in - where the paper would thicken the part in the slot enough to keep it in there.  Again, sounds hard to do without seeing the paper and doesn't sound too permanent.
« Last Edit: July 31, 2003, 08:21:10 pm by REBIRTH »
:) Rotate or die! :)
pepsidx20
« Reply #3 on: July 31, 2003, 09:03:25 pm »
 I tried the paper, did'nt hold too good.  I guess i better go talk to mr Elmers....
 Another question should the molding just wrap around the curves? Or should I cut a slit in it help it contour better?
hyiu
    • www
« Reply #4 on: July 31, 2003, 09:57:19 pm »
I think Mr. Elmer Glue dires too slow in this application....
you need something that dires very fast...
if you go to Radio Shack... you should be able to get hot glue gun, glue sticks... etc. for less than $10.... well worth it...
and yes.... cut slits to help it contour better...
hope it helps...
TalkingOctopus
    • My Arcade
« Reply #5 on: August 01, 2003, 12:12:56 am »
Hot glue is the ticket.
However, it may be tough to get the t-molding to stay around the corners w/ the hot glue.  I would recommend some fast setting epoxy for the corners which sets in about 5 min.  You can find the fast epoxy for about 2$ at a hardware store.
Good Luck.
Apollo
    • Eight Bells
« Reply #6 on: August 01, 2003, 12:55:40 am »
Contact adhesive is the way to go, easy to use and very strong.
Trust me I'm a doctor.
jelloslug
  • Last login:May 25, 2005, 03:55:59 pm
  • Splut!
    • Jelloslugs Arcade
« Reply #7 on: August 01, 2003, 11:47:30 am »
Try the high temp hot glue for the corners (they have it all walmart)  It seems to set up faster.
mclaught
  • Last login:April 20, 2006, 08:09:11 pm
« Reply #8 on: August 01, 2003, 01:03:17 pm »
Find the right Liquid Nails mix for rubber/wood and you're golden. That stuff will hold damn near anything.
meta87
  • Last login:September 30, 2004, 07:36:28 pm
  • Dont Mess with Texas
« Reply #9 on: August 01, 2003, 01:05:56 pm »
I second liquid nails. That stuff is strong!
pepsidx20
« Reply #10 on: August 02, 2003, 01:27:34 am »
Elmers was a bust. :( My wife has little  glue gun but that didnt  work too good either. Liquid nails here I come.
