Author Topic: NSM ESVI PARTS  (Read 3512 times)
bikemanokc
  • Last login:May 28, 2010, 06:58:49 pm
NSM ESVI PARTS
« on: May 14, 2010, 10:40:11 am »
Does anyone know where I can order parts for an NSM Cosmic Burst? I need the optional 3rd and 4th speaker connector. Thanks! :dunno
Ken Layton
  • Guru
  • Technician
Re: NSM ESVI PARTS
« Reply #1 on: May 16, 2010, 10:14:10 pm »
You can buy NSM jukebox parts through any authorized NSM distributor:
http://www.nsmmusic.com/
bikemanokc
Re: NSM ESVI PARTS
« Reply #2 on: May 17, 2010, 09:26:59 pm »
Thanks for the link Ken!
lilshawn
  • Last login:March 08, 2026, 07:17:46 pm
Re: NSM ESVI PARTS
« Reply #3 on: June 02, 2010, 11:21:12 am »
installing the 3/4 speaker connector involves adding an additional amplifier, the actual speaker connector, signal and power wires.
it is a little involved but it is a simple install though.
this amp is capable of driving a 2 ohm load, you could just add more speakers to the existing amp. it can handle it. they say it's 800 watts at 2 ohms, so could be safe to assume 600 without damage at 2 ohms (300 RMS). just keep a load on the amp between 8 and 2 ohms and you will be fine.
REMEMBER:
series speaker connections, add all the ohms together for total load rating.... parallel speaker connections: take the first speaker ohm rating and divide by 1/2 for each additional speaker.
example: 2 of the same 6 ohm speakers in parallel on one channel: 6/2 = 3ohms adding a third speaker and it drops to 1.5 ohms. (3/2 = 1.5)
example2:3 8 ohm speakers in parallel is 2 ohms. 8/2 = 4 and 4/2 = 2
to double check you can read the line with a volt meter set to resistor check. as actual results from calculations vary due to wire resistance and differences in speaker manufacturing.
