Author Topic: Project 64 + Mala  (Read 5709 times)
TPA5
  • Last login:May 30, 2017, 10:25:16 pm
  • Wanting A Cab
Project 64 + Mala
« on: May 12, 2010, 09:12:23 pm »
Hey ya'll,
I'm having a problem with Project 64. Whenever I try to launch a 64 game from within Mala (version 1.05) it opens Project 64 (version 1.6), hangs for a moment, then Project 64 gives me the error "attempt to open file failed". So, I Googled abit, and played around with the command-line parameters. I have tried "%path&/%rom%.%ext%", and I have tried it without quotes. I have a complete list of my 64 games whilst in Mala, and the snapshots even work. I can run the 64 games in Project 64 fine outside of Mala, and I can even use Maximus Arcade to launch them with no problem. So, I am not a stupid guy, but I am stymied by this problem. Help on this matter would be very much appreciated!
Thank you!
PS: I should also point-out that I have my NES, SNES, and MAME all working from within Mala flawlessly. Its just Project 64 that's giving me gears.
« Last Edit: May 12, 2010, 10:11:08 pm by TPA5 »
TPA5
  • Wanting A Cab
Re: Project 64 + Mala
« Reply #1 on: May 13, 2010, 11:54:57 pm »
Sorry, don't want to sound impatient, just curios if anyone knows anything?
andrewbean90
  • Last login:October 04, 2012, 05:55:56 am
  • do you like it?
« Reply #2 on: May 14, 2010, 01:04:27 am »
Try %path%/%rom%.%ext% or just "%rom%.%ext%" with or without quotes or just %rom% with or without quotes
Celsius
  • Last login:May 10, 2015, 11:40:41 am
    • Rcade project
« Reply #3 on: May 18, 2010, 03:01:00 am »
Go to http://www.emuchrist.org/cpviewer/applications.htm, get the hacked .exe for project64 and use the standard command line.
TPA5
  • Wanting A Cab
« Reply #4 on: May 18, 2010, 01:05:52 pm »
I got it working, finally. I realized that when you try to have Mala set the command line default, it puts a backwards slash (\) not a forward slash (/). Duuuur!
Once I put a forward slash it worked fine. I can't believe I didn't pick up on that sooner.... :banghead:
Anyway thanks for the help guys!
