Author Topic: My paint is drying and looks lumpy and webby - Help!!  (Read 4421 times)
zzaz3
  • Last login:May 12, 2012, 02:46:49 am
« on: May 12, 2010, 02:11:08 pm »
My paint is drying as I type this and it doesn't look right at all.  It looks like there's webbing underneath or something.  Its lump and just flat, even though I painted on a flat surface.  Does anybody know what it's doing this?
  • Last login:July 23, 2025, 07:04:20 pm
Re: My paint is drying and looks lumpy and webby - Help!!
« Reply #1 on: May 12, 2010, 02:16:33 pm »
Did you put it on too thick?
Don't worry, though, all is not lost.  Let it dry completely, lightly sand, and repaint.  This is how you would get a nice finish anyway.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #2 on: May 13, 2010, 09:36:09 am »
What type of paint did you use?
More than likely it will have reacted with the paint beneath.
Once it has dried sand it down as suggested and try a test paint over the worst area to see if it reacts again.
If it does then you will need to strip all the paint off or use a barrier primer.
Regards
Alan Hood
ami-man
Uk
  • Last login:October 30, 2025, 09:56:45 am
« Reply #3 on: May 13, 2010, 06:25:05 pm »
Did you prime the surface first to seal it?
zzaz3
« Reply #4 on: May 13, 2010, 07:41:41 pm »
Yeah, I ran out of paint so I when out and bought some more, but the new paint I bought needed to go over primer.  I sanded it down, primed it, and then painted it.  Thanks for the help guys.   ;D
