Author Topic: Soft to create ini or cfg files?  (Read 2408 times)
abispac
  • Last login:November 21, 2025, 11:24:52 pm
« on: May 11, 2010, 02:50:36 pm »
Im having problems compiling mame,and the only thing i do that for its because, i want to remove the nag screen, now i use to compile mame from some time now, and never had problems with it, so i thought, wile i find whats what im doing wrong, i can use one of those piece of software i remember that they where use to batch create custom ini or cfg files to avoid the nag screen, but i use the search function here and nothing comes up, so i was wondering if someone can help.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: Soft to create ini or cfg files?
« Reply #1 on: May 12, 2010, 09:34:29 am »
if the content of said .ini or .cfg files is the same, and only the filename is changing, romlister can do that for you.
it's been so long since i've used a version of mame with nag screens that i don't recall what the file created contains anymore.
this tutorial might help:
http://wiki.arcadecontrols.com/wiki/RL_tutorial_batchFiles
  • Last login:Today at 06:44:21 pm
« Reply #2 on: May 15, 2010, 05:00:06 am »
If I remember correctly, it has to be a cfg file and the cfg file can be "empty" but the structure needs to be there.  So take a cfg file from a game, empty it out, leaving only the headers and footers and copy away.
Hoopz
  • Last login:November 24, 2025, 06:24:57 am
  • Intellivision Rocks!
« Reply #3 on: May 15, 2010, 07:40:14 pm »
Try CFG Magician and see if it's what you need:
http://forum.arcadecontrols.com/index.php?topic=88948.0
abispac
« Reply #4 on: May 16, 2010, 02:03:12 pm »
thanks ill give at try
