Author Topic: Spinners for arcade PCBs (also trackballs)  (Read 2026 times)
Boingo
  • Last login:March 14, 2014, 09:13:41 pm
« on: May 08, 2010, 09:40:05 pm »
Are the commercially made spinners, such as Turbo Twist 2 and Spintrak able to be used with arcade PCBs?
I have a Gigas card (an Arkanoid clone), and am interested in playing it.
Oh yes.  The same thing goes with trackballs, such as Wico or HAPP.
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
Re: Spinners for arcade PCBs (also trackballs)
« Reply #1 on: May 18, 2010, 02:31:11 am »
As far as I know, the Turbo Twist 2 and the Spin Trak are both made with a PC interface.  You'll need to ask Ultimarc or Groovy Game Gear if they will work with a real arcade board. The best spinner for Arkanoid, IMHO is either an original arkanoid spinner, or the Happ Controls replacement.
http://www.happ.com/joysticks/95093100.htm
Most trackballs, except the USB/PS2 trackballs, are made to work with game boards.
Blanka
« Reply #2 on: May 18, 2010, 05:44:07 am »
The spinners have an optical sensing circuit, probably pretty similar to the original arcade spinners, but I think the resolution is way higher in the new spinners. But hook an Arduino in between, and program it to convert the pulse rate.
