Author Topic: closemul pros? winkawaks - need some help *FIXED*  (Read 1907 times)
tony.silveira
  • Last login:September 27, 2024, 03:04:35 pm
    • my baby
« on: May 07, 2010, 06:19:21 pm »
EDIT:  hi all, after spending an afternoon working on this, i FINALLY have it done using closemul in mamewah.  here is my emulator command line if anyone else is interested:
D:\emulators\winkawaks\closemul.exe WinKawaks.exe "[name] %1 -fullscreen"
the weird thing is, my closemul ini is completely blank, no parameters set up.  well, hope this helps someone else
END EDIT
hi guys,
i'm trying to get closemul to work with winkawaks but am running into a problem.
kawaks requires you to press "enter" to pause the emu first, then quits with "ALT+F4" and closemul only allows two keys to be used as a macro to exit.
i do see a bunch of other options within the closemul ini that may be able to help me out but i'm kind of lost on how to use them.
so, anyone out there using closemul with three key presses? can anyone help me get this set up?
much appreciated
« Last Edit: May 09, 2010, 12:04:41 am by tony.silveira »
