Author Topic: has anybody... I need help  (Read 990 times)
andrewbean90
  • Last login:October 04, 2012, 05:55:56 am
  • do you like it?
« on: May 06, 2010, 12:20:57 pm »
has anybody wired a momentary switch to an aimtrak
BobA
  • What Me Worry?
Re: has anybody... I need help
« Reply #1 on: May 06, 2010, 12:25:14 pm »
Sure wire the switch from the 4 pin connector from common to AUX or common to trigger.   If you want any of the other points you will have to solder to p1 to p5 and connect to the common.
andrewbean90
  • do you like it?
« Reply #2 on: May 06, 2010, 01:02:03 pm »
theres 2 prongs whicch one is ground and which one is aux/ the button connection
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: May 06, 2010, 01:11:18 pm »
Either.
