Author Topic: TSOP Flash- Need Help  (Read 2284 times)
XCVG
  • Last login:August 13, 2010, 11:25:54 pm
« on: May 06, 2010, 11:22:07 am »
I've been trying to flash my TSOP using this tutorial: http://www.biline.ca/xbox_mod.htm
So far I've made the controller cable and it works. However, I'm stuck on getting the save onto the memory card. It says to zip it. Zip what? As what? I've tried several things and the Action Replay software still rejects it. The only thing I'm doing wrong is using an unofficial memory card, because that's all I have. That shouldn't make a difference at this point, should it? :dizzy:
Or perhaps I should use a different method? I'm kinda new to this whole XBOX modding thing.
XCVG
Re: TSOP Flash- Need Help
« Reply #1 on: May 06, 2010, 11:10:48 pm »
Nevermind, got it working now. I do have some new questions however.
1. FTP isn't working. Using FlashFXP, correct IP address (I think). Going through a router. Am I missing something?
2. I can't figure out Avalaunch's file manager. For instance, what is with the queue thing?
