Author Topic: Tab key not working on compiled mame  (Read 3212 times)
abispac
  • Last login:Yesterday at 10:13:01 pm
« on: May 01, 2010, 07:40:25 pm »
Its anyone having problems? i have been compiling mame builds for some time, never had problems, but now since mame 136 mame compiles just fine, but if i try to use the tab key, i get an error and the game closes, im i doing somenthing wrong? thanks for any help
abispac
Re: Tab key not working on compiled mame
« Reply #1 on: May 03, 2010, 12:45:18 pm »
bump, cus i need help on this, i have tried to compiled again , same problem...
dgame
  • I am no Jedi
« Reply #2 on: May 03, 2010, 04:49:16 pm »
Does an officially compiled [downloaded] Mame binary work?
Try moving/renaming/deleting the default.cfg file usually found in the \cfg folder under where you installed Mame.
I am not sure if it is related to your problem but that file is the one that can redefine the interface keys including Tab. Just guessing.
abispac
« Reply #3 on: May 07, 2010, 12:04:32 pm »
a regular mame build works ok, its the compiled mame that gives me the error....
headkaze
  • 0x2b|~0x2b?
« Reply #4 on: May 08, 2010, 04:06:55 am »
Is it an optimized build? Mamedev recommend people don't compile with optimization.
  • Last login:Yesterday at 04:50:43 pm
« Reply #5 on: May 10, 2010, 05:38:46 pm »
Try the "1" button.  After I compiled that's what worked for me.
abispac
« Reply #6 on: May 11, 2010, 02:40:47 pm »
and i notice the pause buton exits the app too, wierd.... and no its not an optimized build.
