Author Topic: Vector Games on MAME  (Read 2350 times)
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« on: April 28, 2010, 01:56:59 pm »
why is the image is 'zoomed' in MAME when trying to run at the actual resolution of a vector game?  Also I used the resolution tool and when i check the ini's they do not specify a resolution for Vector games.  What resolution are you using for games like asteroids and starwars, and Tempest?
SailorSat
  • Last login:Yesterday at 04:28:07 pm
    • For Amusement Only e.V.
Re: Vector Games on MAME
« Reply #1 on: April 29, 2010, 12:53:15 am »
If I remember all games are rendered out at 640x480 even if the Vectors could have higher resolutions.
Tried to change that myself a while ago but in the end it didn't work as I wanted.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
Blanka
« Reply #2 on: April 29, 2010, 02:57:14 am »
That's why they call it VECTOR  ;D !
Resolution independent graphics. Mame renders it as bitmap, so the higher resolution you can get, the best. On a old CRT that supports a WHOPPING 2048x1536: excellent!. On a 30 inch Cinemadisplay with 2560x1600: Excellent! 640x480: Blasphemy!
taylormadelv
  • Last login:February 18, 2019, 05:46:59 pm
« Reply #3 on: May 02, 2010, 02:50:33 pm »
Maybe match your screen res with the pixel count of the vector game? ie: 800 x 600?
