Author Topic: Need Help Quick!!! Sony RVP-6010  (Read 1970 times)
ninjazx7
  • Last login:March 22, 2006, 11:33:02 pm
« on: July 30, 2003, 04:29:26 pm »
Hi Guys,
I haven't been here in a while, but I built a Jamma machine to play Golden Tee 99 and Mortal Kombat 3 Ultimate.
Anyhow, I currently have a 27" tv hooked up that I use for the display. I found a converter to go from RGB --> NTSC and it works ok. Here's the dilema that I need some help with....
The company I work for is moving buildings and they don't have room for a Sony RVP-6010. This thing is a 60 inch widescreen projection monitor that you hook your computer up to. It has a scratch on the screen, but works just fine. It has inputs for R, G/G SYNC, B, SYNC/HD, and VD, plus a ton of other hookups.
Does anyone have any experience with these projectors? Anybody know if I'd be able to hook a JAMMA harness up to this beast?
Thanks alot,
Matt
hyiu
    • www
Re:Need Help Quick!!! Sony RVP-6010
« Reply #1 on: July 30, 2003, 04:37:16 pm »
ok... I have no clue whether you can hook it up or not...
but my suggestion is....  ;D ;D  bring it home if you can...
haa ahaaa haa.... and then take your time to hack it so that it works....
if not, the arcadevga card from Ultimarc should be of help....
Hoagie_one
  • Um....whats a cabinet
« Reply #2 on: July 30, 2003, 04:40:23 pm »
always take the 60 inch screen if its offered to you.  Worry about how you can use it after
Snarbald
  • Last login:September 27, 2006, 10:38:25 pm
  • I hate pants!
    • snarbald.com
« Reply #3 on: July 30, 2003, 05:57:18 pm »
I think everyone here can agree that you are now obligated to make a showcase mamecab.
(or, where is this 60" screen and is it up for grabs... ;D)
