Author Topic: I-Pac Wire  (Read 1760 times)
Lumpy
  • Last login:July 13, 2005, 11:27:35 am
  • Doh!!
I-Pac Wire
« on: July 30, 2003, 04:19:13 pm »
Since I haven't seen my I-pac yet  (Hopefully still sitting on my front porch). I'm not sure what size of wire I need to hook everything up.  I would like to stop at the hardware store on the way home to get some disconnects and wire.  Could someone tell me what gauge I need or do people just use Cat-5.  I remember reading a discussion a while back, but you try doing a search for wire.  :o To many posts.  Thanks in advance....only a half hour left till I can go home and play.
Will this work?
UL Recognized Hookup Wire 22 AWG
$4.79 Brand: RadioShack
Catalog #: 278-1221
(Three 90' spools of solid core, 22 gauge wire. Hookup is priced by the spool. 3-spool sets include three different colors.
« Last Edit: July 30, 2003, 04:24:08 pm by Lumpy »
Jarozi
  • Last login:February 27, 2017, 06:44:40 am
Re:I-Pac Wire
« Reply #1 on: July 30, 2003, 04:42:12 pm »
Also, what gauge wire should be used for running power from the computer power supply to the coin door lights/trackball light?
Jarozi
Tiger-Heli
    • Tiger-Heli
Re:I-Pac Wire
« Reply #2 on: July 30, 2003, 05:02:59 pm »
Catalog #: 278-1221
That's fine if you're not doing removable panels, except it's a typo (called R/Shack earlier).  It's Three 90' spools for $4.79 each spool, or about $15.  They sell individual spools with a different p/n, though.
Lumpy
  • Doh!!
Re:I-Pac Wire
« Reply #3 on: July 30, 2003, 05:15:30 pm »
Well I left work before anyone replied so I'm going to do a mock up with Cat-5.  I'm thinking of doing a modular control panel, but don't know exactly how to do it.  I've heard of people using Molex.....does radio shack sell that?  Kind of an all around newbie, but I now have my I-pac in hand.... ;D
« Last Edit: July 30, 2003, 05:15:45 pm by Lumpy »
pointdablame
Re:I-Pac Wire
« Reply #4 on: July 30, 2003, 05:55:41 pm »
so is 22guage wire considered THE wire size to use on a CP, or does it not matter.
I didn't think this warranted a new thread, so I thought I'd ask here. Bump for you since I can't be much help otherwise :)
first off your and idiot
Tiger-Heli
    • Tiger-Heli
Re:I-Pac Wire
« Reply #5 on: July 30, 2003, 06:03:35 pm »
CP's are not really fussy.  Cut DB25 cable works fine and the internal wires on that are like 28 or 32 gauge (thin!!).
Personally, I like 22 because the RED terminals are 18-22 gauge, so you have a thin enough wire that you can use 2 in one connector if needed, but thick enough that you can get a good crimp.
Apollo
    • Eight Bells
Re:I-Pac Wire
« Reply #6 on: July 30, 2003, 06:28:19 pm »
I would avoid using solid core wire if possible.
Go for stranded it may save you headaches down the track.
