Author Topic: 60 in 1 vertical and a wide LCD monitor - no monitor chosen yet  (Read 1841 times)
dynasty_trs
  • Last login:May 24, 2010, 09:06:56 pm
  • Born to Soar
    • You can follow my build here!
Thinking about a new build and may be asking a stupid question.
If I get the 60 in 1 vertical and connect an LCD screen to it, would the picture be sideways in its normal orientation / mount?
 - if yes, that is obviously a good thing as it will be correctly vertical once I turn the monitor 90 degrees upward.
Yes  ???
 - OR does the monitor need to be able to flip the picture?
TIA!
Kevin Mullins
    • Me on Myspace
Re: 60 in 1 vertical and a wide LCD monitor - no monitor chosen yet
« Reply #1 on: April 27, 2010, 01:43:00 am »
Yes  ???
Yes
dynasty_trs
  • Born to Soar
« Reply #2 on: April 27, 2010, 06:53:38 pm »
Awesome.  Thanks!
On another note not so much about the monitor, if I get the 60in1, will it come with a jamma/wiring harness for the CP etc...???
Kevin Mullins
    • Me on Myspace
« Reply #3 on: April 27, 2010, 09:21:10 pm »
I doubt it .... but ask the seller for sure.
nitz
  • Last login:November 24, 2015, 07:57:29 pm
« Reply #4 on: April 27, 2010, 09:51:16 pm »
Do 60in1 jamma boards have the option of keeping the aspect ratio correct on a widescreen? I would make sure of this before you buy a widescreen monitor. Some folks don't seem to mind a stretched image, but personally that would drive me bonkers! :dizzy:
