Author Topic: Hantarex Polo Problem [Fixed]  (Read 2284 times)
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
« on: April 21, 2010, 02:06:28 pm »
I have a 25" Hantarex Polo with issues. It seems like I may be chasing two problems here. First the screen was completely green. I pulled out the green driver transistor to see if it was the tube or the board. I had nothing so I turned up the screen adjustment on the flyback and got a white screen. I figured I had a blanking problem and a problem with the green video. I can't seem to solve either problem. I checked or replaced: T4 T5 C2 IC1 & T1. I checked everything in the green drive and just can't find anything wrong. I'm not quite sure where to go with this so any help would be greatly appreciated.
« Last Edit: April 26, 2010, 08:20:25 pm by Karetaker »
grantspain
Re: Hantarex Polo Problem
« Reply #1 on: April 21, 2010, 02:17:16 pm »
check the +12v on the lm1203n,less than 11vdc then start checking the caps around ic105(12 v reg)
make sure your contrast is not fully down and gains on neck card
i guess another chassis has been tested on the crt to prove no problem there or the cab itself
arcadecup.com
  • Last login:April 26, 2022, 04:00:06 pm
« Reply #2 on: April 21, 2010, 06:07:00 pm »
corrupt lm1203 ic, d6..
make sure none of the transitor heatsinks on the neckboard are touching.
pot opens on the neckboard maybe.
Chad Entringer
Web: www.arcadecup.com
Phone: 920-883-8905
Karetaker
« Reply #3 on: April 21, 2010, 07:53:47 pm »
I'm recapping it tomorrow. I will check the 12v when I put it back in. Contrast was up. I don't have another chassis. It's not the game itself I pulled it out and have the same problem with my test board on the bench.
I already replaced the LM1203. I already tested the pots and will double check the heatsinks tomorrow.
Thanks much!
