Author Topic: Hacking Dreamcast video and sound  (Read 2184 times)
Stormdemon
  • Last login:June 10, 2004, 01:20:16 pm
« on: July 29, 2003, 06:41:31 pm »
Hello! Any Dreamcast user out there with experience building cabinets with a Dreamcast insde? I hope you can help me with this:
First doubt:
I have a Dreamcast and I plug it to my SCART TV with a RGB cable. I'm going to hack this cable in order to drive the sound to a pair of amplified PC speakers. Is it enough to cut and wire left input sound and right input sound to the speakers or do I need any ground too? I'll have the DC connected to the TV for video and to the speakers for sound.
Second doubt:
I've noticed some games output 15khz non-interlace picture as you can see real scanlines . For instance, SF3 double impact or Last Blade 2. Others, most of them, output interlace picture (eg SF3 thrird strike). My question is: what modification do I need to make to the RGB cable in order to obtain non-interlace picture in all games? I've been reading DC2JAMMA and I don't have clear if I need that circuit or not? It says it may be needed for some arcade monitors and not for others, but what about SCART TVs?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Hacking Dreamcast video and sound
« Reply #1 on: July 29, 2003, 07:13:16 pm »
There is some info on hacking the dreamcast on this site.  Not sure if there is the info you are looking for.  It mostly is about hacking a vga box.
Stormdemon
« Reply #2 on: July 30, 2003, 08:29:24 am »
I'd rather hack a RBG cable than the VGA box because not all games run in the VGABOX.
CanStick
  • Last login:May 02, 2004, 12:39:58 pm
    • CanStick Controls
« Reply #3 on: July 30, 2003, 09:09:46 am »
Hi there...I can answer your first doubt for you....yes, you will need a ground.  Take the ground from the cable and split it to go with both audio channels to the speakers.
Sorry I can't help you with your second doubt though....
Terry.
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #4 on: July 30, 2003, 11:42:20 am »
I've found that if you connect the vga box about 10 seconds after you power on the DC all my my non-vga box games will run.
Minwah
    • MAMEWAH
« Reply #5 on: July 30, 2003, 11:58:29 am »
Terry.
Correct, but also remember that audio to a Scart plug is not amplified - so it will be crap (or not work at all) if you wire directly to speakers.  You'll need an amp between DC and speakers.
Second Doubt:
I think the circuit described at DC2Jamma is simply for obtaining the correct video sync from the Scart lead for an arcade monitor.  Since you are using a Scart TV you do not need to do this - it already has the correct composite sync.
AFAIK you are stuck with whichever mode the DC outputs - I could be wrong tho...
I personally have never seen any reason to alter the Scart output of the DC - it looks great!
CanStick
    • CanStick Controls
« Reply #6 on: July 30, 2003, 02:35:03 pm »
Terry.
I don't know anything about SCART, but in the first post, he said he was going to connect it to amplified speakers...  ;)
If he wasn't, then yes, for sure some kind of amp would be needed...
Generic Eric
« Reply #7 on: July 30, 2003, 04:45:02 pm »
Check this place out.  Very informative site.
Minwah
    • MAMEWAH
« Reply #8 on: July 30, 2003, 06:45:53 pm »
My mistake, sorry I must've misread  :-[, no amp will be needed then.
