Author Topic: Mame compile woes  (Read 6355 times)
Dudeman
  • Last login:April 23, 2025, 06:42:24 pm
  • Ecky ecky ecky ecky P'Tang! Zoop-boing mmmzoesm...
Mame compile woes
« on: April 09, 2010, 11:48:16 am »
I'm having a heck of a time trying to compile. I'm trying to compile v106, because I read somewhere in a past thread that it was the treat, my roms are all checked against that version, and I don't really want to go through the rom "collection/checking/fixing/deleting unwanted" process again. I know that version still had the high score capability but had the no nag switch removed, so that is what I'm trying to compile for.
I've used Headkaze's Mame Compiler v1.17 but I get:
makefile:334: src/windows/windows.mak: No such file or directory
makefile:339: src/cpu/cpu.mak: No such file or directory
makefile:340: src/sound/sound.mak: No such file or directory
mingw32-make: *** No rule to make target `src/sound/sound.mak'.  Stop.
When I try and manually do it (meaning command line) following Mr.Do's instructions, I get the same thing.
So I try it on a different box. 32bit so I can't use the Mame Compiler (I assume because 64 means it is 64bit, right?) so I download the compile stuff from mamedev.org.
I try to use mingw-mame-w32-20100102.exe and I get:
make: Interrupt/Exception caught (code = 0xc0000005, addr = 0x77c47098)
I try to use mingw-mame-20070810.exe and I get:
Compiling src/windows/wind3d.c...
cc1.exe: error: unrecognized command line option "-Wno-unused-functions"
mingw32-make: *** [obj/mame/windows/wind3d.o] Error 1
I try to use mingw-mame-20070617.exe and I get:
src/windows/wind3d.c:18:17: d3d.h: No such file or directory
In file included from src/windows/wind3d.c:21:
src/windows/d3d_extra.h:5: error: syntax error before "D3DVALUE"
src/windows/d3d_extra.h:5: warning: no semicolon at end of struct or union
src/windows/d3d_extra.h:5: warning: type defaults to `int' in declaration of `dv
SX'
src/windows/d3d_extra.h:5: warning: data definition has no type or storage class
src/windows/d3d_extra.h:6: error: syntax error before "D3DVALUE"
src/windows/d3d_extra.h:6: warning: no semicolon at end of struct or union
src/windows/d3d_extra.h:6: warning: type defaults to `int' in declaration of `dv
SY'
src/windows/d3d_extra.h:6: warning: data definition has no type or storage class
src/windows/d3d_extra.h:7: error: syntax error before "D3DVALUE"
src/windows/d3d_extra.h:7: warning: no semicolon at end of struct or union
src/windows/d3d_extra.h:7: warning: type defaults to `int' in declaration of `dv
SZ'
src/windows/d3d_extra.h:7: warning: data definition has no type or storage class
src/windows/d3d_extra.h:8: error: syntax error before "D3DVALUE"
src/windows/d3d_extra.h:8: warning: no semicolon at end of struct or union
src/windows/d3d_extra.h:8: warning: type defaults to `int' in declaration of `dv
RHW'
src/windows/d3d_extra.h:8: warning: data definition has no type or storage class
src/windows/d3d_extra.h:9: error: syntax error before "D3DCOLOR"
src/windows/d3d_extra.h:9: warning: no semicolon at end of struct or union
src/windows/d3d_extra.h:9: warning: type defaults to `int' in declaration of `dc
Color'
src/windows/d3d_extra.h:9: warning: data definition has no type or storage class
src/windows/d3d_extra.h:10: error: syntax error before "D3DCOLOR"
src/windows/d3d_extra.h:10: warning: no semicolon at end of struct or union
src/windows/d3d_extra.h:10: warning: type defaults to `int' in declaration of `d
cSpecular'
... and on and on.
What the heck am I doing wrong? Besides trying to do something above my pay grade.
BTW... All of this is using mame0106s.zip source code. Not even adding in any diffs.
Eddie_Brock
  • Last login:February 26, 2014, 12:00:34 pm
Re: Mame compile woes
« Reply #1 on: April 09, 2010, 12:26:05 pm »
I would follow the details here: http://mrdo.mameworld.info/compile.html
I had trouble using HeadKaze's program as well, but once I found this guide, I had no problem compiling on my computer. I hope this helps. (and no offence to HeadKaze intended)
Dudeman
« Reply #2 on: April 09, 2010, 12:42:45 pm »
Yup. Tried that. It says, "NOTE: This is to compile MAME starting with version 0.119" so I assume that is a problem as I'm trying to compile 106.
headkaze
  • 0x2b|~0x2b?
« Reply #3 on: April 09, 2010, 02:49:36 pm »
You can download the older version of Mame Compiler for compiling earlier versions of Mame from here.
I'll have to check to see if MC will compile the latest version a few people have said it's not working.
Dudeman
« Reply #4 on: April 09, 2010, 03:07:52 pm »
Downloaded that version to another system. Tried to compile without adding any diff files... here's the result:
Compiling Mame...
Using Parameters  -j3
Compiling src/windows/wind3dfx.c...
Compiling src/windows/winddraw.c...
mingw32-make: *** [obj/mame/windows/winddraw.o] Error 1
mingw32-make: *** Waiting for unfinished jobs....
mingw32-make: *** [obj/mame/windows/wind3dfx.o] Error 1
Finished!
0 Hours 0 Minutes and 1 Seconds Elapsed.
« Last Edit: April 09, 2010, 03:14:24 pm by Dudeman »
Dudeman
« Reply #5 on: April 09, 2010, 03:23:53 pm »
New info.
I downloaded v0105... same error.
I downloaded v0112... it's currently compiling. So maybe the problem is the version of MinGW that I'm using. Question is... what is the right version?
Dudeman
« Reply #6 on: April 11, 2010, 09:58:39 pm »
I was finally able to compile version .0123 with Mame Complier 117. Still can't compile lower versions.
headkaze
  • 0x2b|~0x2b?
« Reply #7 on: April 12, 2010, 10:40:35 am »
Use the MinGW version that comes with Mame Compiler.
Dudeman
« Reply #8 on: April 12, 2010, 11:03:49 am »
Tried that. No go.
Eddie_Brock
« Reply #9 on: April 12, 2010, 01:25:03 pm »
I'm pretty sure that from my experience, .NET framework 3.5 was needed to do the compiling. My arcade machine doesn't have .net, so I had to do it on my PC. Worked fine, just transferred everything over afterwards and it worked fine.
Maybe double check that you have .net 3.5, and Direct X installed.
headkaze
  • 0x2b|~0x2b?
« Reply #10 on: April 12, 2010, 02:32:13 pm »
Unless I'm missing something this is telling me you're using a different MinGW version to the one installed (it's happened before)
I could be wrong though!
Dudeman
« Reply #11 on: April 12, 2010, 02:55:28 pm »
Well, I downloaded the source code AGAIN for 0106 and tried to recompile. Errors, but I started messing with the checkboxes. I assumed because I had a 64bit Quad core, i should check those boxes, but nope. Leaving everything blank EXCEPT "Clean Compile" and "Disable Warnings as Error" allowed me to compile 0106.  :cheers:
I started adding diffs (0106-0106u10.diff to be exact), and that's where I'm running into problems. 1st one said something along the lines of:
src/usrintrf.c:420: error: unterminated #ifndef
So I edited that file, found where the ifndef was opened and added the close tag after that section, which happened to be segmented by comments.
Ran again and now I'm getting:
Compiling src/timer.c...
Compiling src/ui_text.c...
Compiling src/unzip.c...
Compiling src/usrintrf.c...
src/usrintrf.c:440: error: conflicting types for 'ui_init'
src/usrintrf.h:91: error: previous declaration of 'ui_init' was here
src/usrintrf.c: In function 'ui_init':
src/usrintrf.c:460: error: 'load_save_state' undeclared (first use in this function)
src/usrintrf.c:460: error: (Each undeclared identifier is reported only once
src/usrintrf.c:460: error: for each function it appears in.)
src/usrintrf.c: At top level:
src/usrintrf.c:5235: warning: conflicting types for 'add_filled_box'
src/usrintrf.c:5235: error: static declaration of 'add_filled_box' follows non-static declaration
src/usrintrf.c:1068: error: previous implicit declaration of 'add_filled_box' was here
src/usrintrf.c:5245: warning: conflicting types for 'add_black_box'
src/usrintrf.c:5245: error: static declaration of 'add_black_box' follows non-static declaration
src/usrintrf.c:4261: error: previous implicit declaration of 'add_black_box' was here
mingw32-make: *** [obj/mame/usrintrf.o] Error 1
Finished!
0 Hours 0 Minutes and 35 Seconds Elapsed.
So I do have a working 0106, but I'll have to decide how much time I want to spend on these diffs. Value added vs. time.
Thanks for the input guys. Especially Headkaze. If I had to commandline this whole thing every time I'd have gone postal.
« Last Edit: April 12, 2010, 02:56:59 pm by Dudeman »
Gh0sty
  • Last login:November 17, 2025, 03:43:45 am
  • flying Mame Player
« Reply #12 on: April 14, 2010, 07:33:06 pm »
headkaze i followed everything what you have wrote about how to setup everything, but when i try to
compile i get this errors:
MameUI.mak:40 warning: overriding commands for target ´mameui32.exe´
makefile:664: warning: ignoring old commands for target ´mameui32.exe´
Compiling src/emu/cpu/m68000/m68kmake.c...
Compiling src/osd/windows/strconv.c...
Compiling src/osd/windows/windir.c..
gcc: CreateProcess: No such file or directory
mingw32-make ***[obj/winui/mame/emu/cpu/m68000/m68make.o] Error 1
...and so on with few more No such file or directory, then finished.
what could it be?
R
Gh0sty
Gh0sty
« Reply #13 on: April 14, 2010, 08:06:17 pm »
update!
the Problems just happen with the 0137source,
i tried with 0128source and it worked, strange...
what could be the problem with 0137s ?
R
Gh0sty
Dudeman
« Reply #14 on: April 15, 2010, 09:04:33 am »
Try messing with the check boxes. I got different results with different selections.
