Author Topic: How do I remove the coin door?  (Read 1174 times)
kingfish
  • Last login:July 23, 2010, 04:09:39 pm
« on: April 08, 2010, 08:06:55 pm »
I need to paint the front of a cabinet and need to remove the entire coin door.  Is there a way to do it?  It appears that a rivet is holding the frame of the door on.  Its a galaxian, by the way.  Thanks.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: How do I remove the coin door?
« Reply #1 on: April 08, 2010, 08:23:42 pm »
Open the door and look inside the cabinet -- there should be nuts on the inside of the cab.
Working: Not Enough
Projects: Too Many
Progress: None
Ken Layton
  • Guru
  • Technician
« Reply #2 on: April 08, 2010, 09:41:53 pm »
There are a total of 4 bolts that are spot welded to the outer frame. On the inside of the cabinet with the cpontrol panel removed, look down inside at the back of the coin door frame and you'll the holes where the recessed nuts are holding the door frame. An 11/32" nutdriver will remove the nuts anf the door will come off.
