Author Topic: Ipac key problem strange repeated key presses that won't stop  (Read 1107 times)
squidbat
  • Last login:July 16, 2010, 03:08:16 pm
I have the older ipac and just upgraded my mame system with new motherboard.When I hook up the ipac in usb or ps2 mode.
It just ramdomly starts really quick key presses on all the different keys, it just starts typing letters in windows.Like all the keys are stuck.The Winpac software shows all the repeated key presses.Tired everything turned off the usb 2 controller and usb keyboard support in the bios nothing helps.None of my keys on the contol panel are stuck down.This is the only thing holding me up from getting my mame system running any help would be wonderful.
JustMichael
  • Mmmmm!! Cheesecake!!
Re: Ipac key problem strange repeated key presses that won't stop
« Reply #1 on: April 05, 2010, 02:43:33 am »
Have you checked to make sure it isn't a wiring issue?  You could disconnect all the buttons and see if it still does it.
CathalDublin
  • Last login:March 01, 2024, 04:05:23 pm
« Reply #2 on: April 05, 2010, 06:04:43 am »
I'd start by removing all the wires from the terminals 1st
If the IPac appears normal now, put them back one by one
Defender(multiwilliams), SF2CE
Whirlwind, Lethal Weapon 3
squidbat
« Reply #3 on: April 05, 2010, 08:03:38 am »
I never messed with the ipac or the control panel i just swaped out the motherboard in the computer and upgraded the hard drive
Ed_McCarron
« Reply #4 on: April 05, 2010, 08:47:04 am »
Dumb question... Is there a real keyboard attached to the cab?  Just tore my iPac apart to find that the real keyboard had fallen behind the pc and was leaning on some keys...   :banghead:
squidbat
« Reply #5 on: April 05, 2010, 12:09:59 pm »
 I have hooked the computer keyboard to the ipac and the computers usb and ps2 ports still same problem keys keep repeating
