Author Topic: SpinTrak Rotary Control Spinner Configuration Help MAME UI64  (Read 3593 times)
jcutler0902
  • Last login:July 14, 2017, 08:42:56 am
« on: April 01, 2010, 08:55:23 pm »
Great site, full of information.
I am in the process of putting together my CP and need some help configuring the Spin Trak with UI64.  I am not married to UI64, as I am also looking at Hyperspin. The MAME Version I am running is 0134S.
The two games at this point are Tempest and Arkanoid.
I have tried a variety of options to get this spinner to work and are not being successfull. Any help is appreciated.
I did verify my system does pick it up via USB.
Thanks in advance
JC
bkenobi
Re: SpinTrak Rotary Control Spinner Configuration Help MAME UI64
« Reply #1 on: April 02, 2010, 12:07:11 pm »
You need to enable mouse input.  If you use the standard version of MAME, you can create a mame.ini file and set it there.  If you stick with the UI version, you need to enable it in the options menu (don't remember where since I haven't used the UI in a couple years).
