Author Topic: Is there a way to connect the analog sticks on 360 controller to a "spinner"  (Read 2313 times)
MAYAman
  • Last login:March 31, 2010, 05:19:37 am
Building an arcade stick and was wondering if you can connect an arcade spinner control to act as a analog stick on the 360 controller being spun around?  I can play Tempest now by using the analog stick but it isn't the same.  Any way to move the analog stick off the pcb and put it on the surface of the arcade stick?  If I can't use the spinner I'd just move the analog stick to the surface of the arcade stick, is this even possible?
thanks!
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
thanks!
I thought you were going to try using the spinner from the MadCatz joystick?
MAYAman
LOL hi Versapak.  Yeah I'm going to try that but if that doesn't work I need a backup plan.
I/O
  • Last login:June 06, 2011, 01:33:10 am
I suggest you buy a GGG TT2.
