Main > Project Announcements
Donkey Kong Themed Bartop
Jigenjuke:
How about shipping for a cost for the bezel artwork. I am a little far away for you, but we have Color ink jel plotters here at school in Japan. I am usre if you asked around the forum you could get someone to print the size of bezel you need for that bartop. It would look great and maybe cost ya 5-6 bucks.
Adam
Bender:
--- Quote from: eaconner on June 14, 2010, 09:22:16 pm ---
--- Quote from: Bender on June 09, 2010, 08:18:13 pm ---I'm having a little difficulty with the sound, how are you doing that part?
Are you going through the mini jack, or the harness, is the jack mono or stereo?
Are your speaker/s powered?
What speaker/s are you using?
Do you have a volume control besides the menu based one?
I am using a 1/2 watt 4 ohm speaker hooked up to the JAMMA connector. I tried using the headphone jack with un-powered speakers and couldn't get enough volume. The board also has a volume control on it that only adjusts the JAMMA speaker. The audio output is only mono.
If you have any other questions please feel free to ask.
Hope that helps,
Eric
Yeah, It turns out you need the 12v going to the board for the sound to work and the headphone jack is only for powered speakers, but I did get the sound going
Thanks for the info!
I might have a way to help you out with the bezel too
What are the overall dimensions of it?
eaconner:
--- Quote from: Bender on June 15, 2010, 02:08:52 am ---I might have a way to help you out with the bezel too
It is 17" wide and 18" tall.
Bender:
PM sent!
eaconner:
Looks like I need to create some custom bezel artwork now.
