Main > Project Announcements
Donkey Kong Themed Bartop
Pages: << < (15/16) > >>
Jigenjuke:
Hey mate, you don't have to create bezel artwork for this project.  I resized what I had for my bartops and zipped it for you.  Hope this helps.
Adam
mike boss:
Great looking project. Amazing attention to detail, a top shelf project all the way around.
Really really good work.
I have three bartop's I'm working on. Sadly I broke one of the monitors so I now need to purchase a 15" LCD.
Was it easy to de-case your monitor ?
Jigenjuke:
--- Quote from: mike boss on June 16, 2010, 08:12:09 pm ---Great looking project. Amazing attention to detail, a top shelf project all the way around.
I agree, great projects!!  Mike You don't have to de-case the monitors.  For the three bartops that I made I kept the monitors in the cases because all of the monitors had nice threads for bolts.  I just put in a cross piece inside the cabinet and mounted the monitor to it.  The weight of the monitor cases is minimal so I just left them as they were.  You can kind of see what I did in this thread.
http://forum.arcadecontrols.com/index.php?topic=85596.0
eaconner:
--- Quote from: mike boss on June 16, 2010, 08:12:09 pm ---Was it easy to de-case your monitor ?
Mike,
It was very easy to de-case the monitor. The plastic bezel was removed by running a small flat head screwdriver around the outer edge to unlatch the plastic tabs.
mike boss:
I appreciate the info, thank you.
Not to take away from your thread, but I ended up breaking the neck of one of my monitors.
I figure a 15" LCD @ $40 used is better (and easier to find) then a 13" arcade monitor.
I'm thinking every little fraction of an inch will help, hence the reason for de-casing.
Again I think you !
(  my trio : http://3.bp.blogspot.com/_QAVXNwPpzL8/S7i8ZkRKhvI/AAAAAAAAEAw/FRnGUolW8FU/s1600/Putting+It+Together+%287%29.JPG  )
Go to full version
