Main > Project Announcements
Donkey Kong Themed Bartop
eaconner:
I've decided to take a break from Buck Rogers and finish this project up.
To Do:
1. Create plexi bezel (I've decided to just paint it black)
2. Mount the monitor and plexi
3. Attach the marquee
I'm going to try and get this finished by Sunday.
--- Quote from: Jigenjuke on June 16, 2010, 08:04:11 pm ---Hey mate, you don't have to create bezel artwork for this project. I resized what I had for my bartops and zipped it for you. Hope this helps.
Adam
Adam, I couldn't get the zip file to open.
Jigenjuke:
Adam
[/quote]
[/quote]
Hey there I just downloaded it and tried to unzip it and I had no problems on my PC at work that doesn't have Winrar and also at home with my PC that does. I had no problems. PM later if you want it. It really is a high quality illustrator file.
Adam
mike boss:
eaconner & Jigenjuke,
Your work is inspiring. Really top shelf projects, they look incredible. I would be proud to have these cabinets in my collection.
I by no means want to take away from this thread, but thank you for all the info.
I ended up getting my 15" LCD monitor which DID fit CASES. And as I've seen done in previous posts I'm simply going to fashion a bracket to install.
I'm proud to say I just need to make the monitor bracket, plexi bracket, and wire up the power.
Thank you guys
http://www.mymissiontomame.blogspot.com/
tevans333:
Any chance of some finished pics??
