Main > Project Announcements
Donkey Kong Themed Bartop
eaconner:
--- Quote from: WhereEaglesDare on June 06, 2010, 10:17:23 pm ---So as I read it that CPO art was custom or was it the same size as an original? Could you post your CPO and marquee art file? I am thinking I may build one following your example...if my wife will let me get away with it.
The CPO is 17"x6" which is smaller than the original. If you have any questions just let me know. Good luck convincing your wife, Luckily my girlfriend doesn't have a problem with my arcade obsession. She still doesn't understand it though. Attached are the CPO and Marquee.
Enjoy,
Eric
WhereEaglesDare:
Thanks ;D Are you going to use custom Bezel art aswell?
Yea she is giving me crap because I havnt gotten the artwork worked out for my other cabinet yet, but other than that its complete. She doesn't understand that customer artwork doesnt just fall from the sky all the time.
Bender:
hey eaconner,
you inspired me to pick up one of those cards
I'm having a little difficulty with the sound, how are you doing that part?
are you going through the mini jack, or the harness, is the jack mono or stereo?
are your speaker/s powered? What speaker/s are you using?
do you have a volume control besides the menu based one?
Thanks so much for any info
eaconner:
--- Quote from: Bender on June 09, 2010, 08:18:13 pm ---I'm having a little difficulty with the sound, how are you doing that part?
Are you going through the mini jack, or the harness, is the jack mono or stereo?
Are your speaker/s powered?
Do you have a volume control besides the menu based one?
I am using a 1/2 watt 4 ohm speaker hooked up to the JAMMA connector. I tried using the headphone jack with un-powered speakers and couldn't get enough volume. The board also has a volume control on it that only adjusts the JAMMA speaker. The audio output is only mono.
If you have any other questions please feel free to ask.
Hope that helps,
Eric
eaconner:
--- Quote from: WhereEaglesDare on June 07, 2010, 06:44:53 am ---Are you going to use custom Bezel art aswell?
I think I'm just going to paint the bezel black to keep the cost down.
One day I will find the time to finish this. I need to get my Buck Rogers pin up and running first.
