Author Topic: What joystick is this? [SOLVED]  (Read 1500 times)
shrunkenmaster
« on: March 20, 2010, 03:38:23 pm »
This was on a Tron CPO I acquired recently, anyone shed any light on it? Up for grabs if anyone's interested, along with a Tron CPO (just the metal panel, no parts)...
« Last Edit: March 21, 2010, 01:41:47 pm by shrunkenmaster »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: What joystick is this?
« Reply #1 on: March 20, 2010, 06:21:09 pm »
You left out the most important part, the top. Is there a hole on the top or no?
That is a rare Wico bat-handle with a metal adapter plate for using it on Midway cabs. They usually have a button on top. Actually, the button is a long plastic stick and at the bottom, below the e-clip there is a plastic disc attached. This disc would push a 5th leaf switch. I don't see that extra switch nor any evidence that the base had it.
So... if the bat has a hole, then it's been inserted into the wrong base. If it doesn't have a hole, then I guess you have a complete, and rare, Wico bat-handle joystick with adapter*.
*That adapter should also be usable on Pacs, Galaga, etc and with any standard joystick with the matching bolt hole spacing.
NO MORE!!
shrunkenmaster
« Reply #2 on: March 21, 2010, 07:29:13 am »
Hey RayB,
Was half asleep as usual. Yes, the hole is there but no button/plastic stick. Would be interesting to see a complete unit and where the 5th leaf would mount.
Thanks for the info my man.
