Author Topic: MameWah & NMS file usage  (Read 1677 times)
Unkis17
  • Last login:March 24, 2017, 12:03:37 am
  • I'd keep on building if i had the space
« on: July 28, 2003, 10:26:06 am »
Has anyone gotten the NMS file to work (For Atari, z26)?  I created one basically it looks like this:
DisplayName | ActualROMName
I put the file path in the EMU CFG file, but it doesn't work.  I also have the setting on ROM folder only.  I have tried the others, but nothing worked.  I don't have a Dat file (cause i don't know where to get one), does this matter.  MinWah said I may need one, but wasn't sure.  He says not many of us are using this feature yet...  Anyone know anything to get this feature working?
Re:MameWah & NMS file usage
« Reply #1 on: July 28, 2003, 01:31:03 pm »
I checked, and you do need to use a DAT file...I'd suggest using Izarams DAT Maker from www.oscarcontrols.com/lazarus for the time being.  Let me know how it goes...
I will change this so that you don't need a DAT file (I think CatVer will only wotk with a DAT too).  I hadn't realised I'd done it like that!  :-[
Unkis17
« Reply #2 on: July 29, 2003, 09:22:46 am »
I did finish a working version of a NMS file!  490 some roms later!
Just for referance for anyone else that is interested in this feature...
1.  You need a working Dat file as well
2.  You need it set to Rom vs Dat
3.  Their can be no spaces between your piping command
  IE,  Display Name|RomName
If anyone is interested in my NMS file just drop me an IM.   Keep in mind this NMS file matches my Atari Roms DIR only since i only have some of the set.  If anyone has a perfect set of Atari Roms, I'll do the NMS file if you can share the info so i can get all the rom names working.
« Reply #3 on: July 29, 2003, 11:04:18 am »
Thanks for comfirming that, sorry I hadn't checked it all previously  :-[
FWIW I have now made it so you can use 'ROM Folder Only' (or any List Gen. Method) with NMS files, and I will improve it so it will trim spaces if this: 'Display Name | RomName' format is used (have you already deleted all those spaces?)
