Author Topic: Jakobud Plans... How accurate?  (Read 9079 times)
nintendoid
  • Last login:February 19, 2026, 09:55:13 am
    • Nintendoid
« on: March 19, 2010, 06:48:04 pm »
Hi Guys
After reading a few comments on various forums, just want to know how accurate the plans on jakobud website are for the nintendo Donkey Kong and Mario Bros widebody are??
  • Last login:Yesterday at 01:37:16 pm
Re: Jakobud Plans... How accurate?
« Reply #1 on: March 19, 2010, 07:10:54 pm »
Probably accurate enough.   ;D
ark_ader
  • I glow in the dark.
« Reply #2 on: March 19, 2010, 08:13:22 pm »
+1  :laugh2:
« Reply #3 on: March 19, 2010, 08:48:16 pm »
Hi Guys
They're probably as good as it gets.
Sectorseven
  • Last login:November 09, 2017, 02:34:50 pm
« Reply #4 on: March 19, 2010, 09:12:08 pm »
It seems fairly accurate to me. There's a thread on the dragonslair forums where some guy listed all the actual dimensions. I'll see if I can find it when I get a chance.
sk8ersublime
  • Last login:December 24, 2025, 07:55:39 pm
« Reply #5 on: March 19, 2010, 10:38:36 pm »
I used them and they were decent. I would have never tried without them. The only problem I had was the middle was wider than the bezel so if u get the bezel or CP first base your width off that and u will be fine.
Sectorseven
« Reply #6 on: March 19, 2010, 11:48:57 pm »
This thread has info on some of the more vague measurements.
http://www.dragonslairfans.com/smfor/index.php?topic=783.0
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #7 on: March 20, 2010, 09:29:34 am »
The answer you seek depends on what you want to use the plans for. If you want to built spot-on accurate repros, then they aren't that accurate. If you want to build cabinets that most people couldn't tell weren't original, then they are as javeryh says -- probably accurate enough.
The widebody plans have been reported as wrong with speculation being that they are just the standard with 4 inches of extra width. I can't seem to find reference to the thread in question, but I do recall the OP being rather ticked as he had already built the cab and none of the parts he had ordered fit (so I would definitely follow sk8er's advice above).
Working: Not Enough
Projects: Too Many
Progress: None
nintendoid
    • Nintendoid
« Reply #8 on: March 20, 2010, 05:01:51 pm »
thanks for the replies.... I have redrawn them in autocad and dimensions and any that didn't add up it was pretty easy to correct.
Ill bear in mind the sizing for when I redrawn the widebody. Ive noticed the vs nintendo (also puch-out and other nintendo) seem to be slightly slimmer and taller.. Does anyone know where I can get these plans or someone who has one that might be willing to help?
Sectorseven
« Reply #9 on: March 20, 2010, 07:51:45 pm »
Could you possibly upload your autocad file?
nintendoid
    • Nintendoid
« Reply #10 on: March 21, 2010, 07:11:33 am »
yeah once I have had it cut out on a cnc router and know the measurements are correct, I will make the autocad drawing available.
Can anybody help with the VS Cabinet??
mwong168
  • Last login:May 28, 2019, 11:38:54 am
« Reply #11 on: March 21, 2010, 09:27:53 am »
I used the jakobud plans for my dynamo showcase build and I did find a few inconsistencies but I was making changes myself to suit my own needs anyways because I had to take into consideration being able to move it down and up my basement stairs.  They are fairly accurate otherwise or will give you a good starting point so just make sure before you cut you check all the measurements first.
Showcase Project [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=93701.0
Bartop Project [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=98410.0
Custom Wireless 360/PC HAPP Fight Sticks [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=100809.0
Visual Pinball Cabinet [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=102628.0
hoffy84
  • Last login:August 02, 2025, 08:45:54 am
  • It's not just a project, It's an obsession....
« Reply #12 on: November 13, 2013, 09:35:23 am »
Hi Nintendoid, Did you ever have any success with the PC10 dimensions? I want to start on a Punch-out!! Cabinet, but can't find any empty cabs in my area to work with, so I need to make a go at it from scratch. Would be awesome if you could share a CAD file.
« Last Edit: November 13, 2013, 09:44:22 am by hoffy84 »
vectoralpha
  • Last login:December 14, 2015, 08:20:30 pm
« Reply #13 on: March 11, 2015, 11:46:29 pm »
looking for Nintendo Mario bros widebody measurements.
thank  you
Gaetan
  • Last login:February 03, 2018, 01:12:51 pm
    • Arcadecab.fr
« Reply #14 on: March 12, 2015, 07:31:35 am »
Hi
If Mario Bros is the same cab as Donkey Kong, take a look at my topic "Donkey Kong plans".
« Reply #15 on: March 12, 2015, 07:46:32 am »
It's not - the Mario Bros. cabinet is a Nintendo widebody cab. There are some significant differences.
Gaetan
    • Arcadecab.fr
« Reply #16 on: March 12, 2015, 08:48:56 am »
I see...  :-\
Only the width ?
Sorry, i don't know.
Generic Eric
« Reply #17 on: March 12, 2015, 10:55:10 am »
I see...  :-\
Only the width ?
This is a good indicator of the differences:
Gaetan
    • Arcadecab.fr
« Reply #18 on: March 12, 2015, 11:54:58 am »
On Jakobud plans the only différence is the width.
I think he used the same side as Donkey Kong but it's wrong.
« Reply #19 on: March 12, 2015, 12:18:23 pm »
This is a good indicator of the differences...
And how do we know those are even real?
