Author Topic: Drilling push button holes in the coin door.  (Read 2136 times)
Dartful Dodger
  • Newer isn't always better.
« on: March 18, 2010, 05:17:00 pm »
I've got a coin door that has two coin slots, but only one coin return.
Each coin slot has a little quarter sign with a small hole in the coin door to allow the signs to be back lit by a small bulb.  Is there a way to widen those holes to allow me to remove the signs and add two rectangle button.
Right now I removed the guts of the coin return tray and put one of the rectangle button there.  It works, but it looks stupid and it's only linked to the player 1 credit input.
I don't want to add the coin credits to the control panel.  I like having to reach down by the coin slots to add credits.
This idea is to obvious for me to be the first to think of it, but I couldn't find any threads on the subject.
FrizzleFried
    • Idaho Garagecade
Re: Drilling push button holes in the coin door.
« Reply #1 on: March 18, 2010, 05:44:28 pm »
Why not add a microswitch behind the current push-button coin returns so when you push the return it activates the microswitch?
Dartful Dodger
« Reply #2 on: March 18, 2010, 07:04:05 pm »
There is just one coin return button and since the mechanics of the button are clearing out two coin slots the button requires a lot of force to push.
Besides that wouldn’t be as clean and pretty as using rectangle push buttons.
northerngames
  • Trade Count: (+18)
« Reply #3 on: March 23, 2010, 10:40:30 am »
have you checked out groovygamegear's coin return buttons they may be a perfect fit for your app.
Dartful Dodger
« Reply #4 on: March 24, 2010, 04:35:16 pm »
Ah now I get it.
I looked at groovygamegear's coin return button.
My coin slot doesn't have a button, the button is metallic the size of a pencil and is half way between the coin slot and the coin return.  There are no wires it's all mecanical.
Now that I realize there are doors like the way I want I don't have to put holes through the one I have, I’ll just buy one already with the holes.
Thanks.
